2 My 1275 Hammer Conversion..
0 Sleeve cylinders?
0 Ironhead in the uk
0 Hi from Spain!
0 Hi From Atlanta
0 Sportster Cobra seat
Last Post: USAFpj
0 77 XLCH oil line routing
Last Post: nychopper
Last Post: Gospelman
0 External breathing systems
Last Post: slamtry
5 Nightster tyre type "-" or "B"
Last Post: wally_m82a1
0 TC88A update ?
0 Too HOT to ride?
0 19'' Cast/Chrome Front Wheel
Last Post: SLW210
Last Post: lehel
0 roadside belt change
Last Post: Blowupster
0 Range With EFI 3.3 Gal Tank
Last Post: corndog76
bore size, hand controls, ironhead, master cylinder, single disk
Old 14th March 2011
vick074's Avatar
vick074 vick074 is offline
Sportster/Buell Model: XLCH sportster
Sportster/Buell Year: 1976
vick074 will become famous soon enoughvick074 will become famous soon enoughvick074 will become famous soon enoughvick074 will become famous soon enoughvick074 will become famous soon enoughvick074 will become famous soon enoughvick074 will become famous soon enoughvick074 will become famous soon enough
Default 1976 XLCH front master Cylinder bore size/hand controls??
Just wondering about getting new hand controls for my 76 XLCH single disk.
I've been told my bore size is 3/4" but have heard of other people using different bore sizes to get better brake performance with their single disk.
Can anyone give me some advice on what I can get away with here, so I know what bore size MC to look for when searching for new controls?
I was looking at these?? http://cgi.ebay.com/ebaymotors/Harle...Q5fAccessories
will they work for me?
Thanks in advance
Old 14th March 2011
rivethog's Avatar
rivethog rivethog is offline
Sportster/Buell Year: '78
Sportster/Buell Model #2: 883 XLH
Sportster/Buell Year #2: 1993
Other Motorcycle Model: 93" Shovel/Pan
Other Motorcycle Year: 1967
rivethog has disabled reputation
If I'm not mistaken, '73 thru '81 single disc uses a 3/4" bore m/c. A smaller bore m/c will work, but it will require less effort at the lever, and have more travel/feel than a 3/4" m/c.
I'm using a 5/8" m/c with a dual disc dresser front end. Lever travel is increased, but it's like "power brakes". I can haul my 1500lb rig down from 70mph with just 2 fingers.
ACE Hardware gr. 8 bolts Krylon & Rustoleum "premium" paint JT-6 waterproof grease, Emgo oil filter Loctite blue red & green AutoZone headlight bulb socket genuine Aftermarket rear fender generic countershaft sprocket Radio Shack 16ga & 14ga wire forks off of a 180mph drag bike Swallow 4.60H18 rear tire 3.50 x 19 Shanghai front
