Keep & Kill
Last Post: fafcpa
1st June 2007
Posts: 155 Sportster/Buell Model: 1200 sport Sportster/Buell Year: 1997
shocks
Hi i have a 1997 1200 sport with the piggy back shocks on the back.It rides extremely hard and i cant get it to soften up.Other than the adjustment on the piggy back part is there any other adjustments on the shocks.Thanks any help will be apprecated
1st June 2007
mostly harmless.. (sssm)
Posts: 4,400 Sportster/Buell Model: 1200S Sportster/Buell Year: 1998 Other Motorcycle Model: Suzuki DRZ400SM Other Motorcycle Year: 2018
Have you tried adjusting the spring preload?
Oh and Welcome to The XL Forum
1st June 2007
Posts: 12,201 Sportster/Buell Model: XL1200 R Sportster/Buell Year: 2006
How much do you weigh? If you're 140 lbs or less, the springs could be too stiff for you. Contact Whittlebeast, he has a pair and can tell you how to adjust them. Did you just buy the bike? Are your sure what suspension components you actually have. Stiff forks, overtightened belt, over inflated tires and other things can also contribute to a stiff ride.
1st June 2007
Posts: 708 Sportster/Buell Model: XLH Sportster/Buell Year: 2001
Air pressure can sure make em ride hard check the air pressure, some people run em above 30 psi front and 40 psi rear.
I like 28 psi front and 38 psi rear.
Welcome to the XLforum
Gold Coast Australia
2001 XLH now with add ons & more bug guts.
With some diamond encrusted tweezers in my hand, me and the pigmy pony over by the dental floss bush.
1st June 2007
Posts: 756 Sportster/Buell Model: XLH 1200 Sportster/Buell Year: 2001
welcome to the forum, can't help much other than to say if you are under 150lb, drink more beer to help increase your weight so that the ride is more comfy. good luck.
1200 XLH, "D" shaped exhaust port, SE 497 cams, 9.5:1 CR, 1.850 inlet & 1.615 exhaust valve, 48 primary & 190 main jet, NOKK needle no shim. 84TQ & 81HP
1st June 2007
Posts: 5,002 Sportster/Buell Model: 1200 Low Sportster/Buell Year: 2007 Other Motorcycle Model: Yamaha FZ1 Other Motorcycle Year: 2008
What do you weigh?
There are two adjusters on each shock. Are they spun in the direction of S (soft) top and bottom. The length of the shock with you sitting on the bike should be right at 12" C to C. This is adjusted with the large ring on the bottom.
If the bike is still riding hard and you weigh anything under 200, something is broke.
AW
1st June 2007
did not realize there was a adjustment on the bottom just adjusted from top being to light is not a problem here im 255
1st June 2007
At 255 you are too heavy for the suspension. Assuming it is stock. You can ride it, but it will never handle correctly. The next question becomes how much money and effort do you want to put in it to make it great?
