Last Post: fafcpa
0 TC88A Programming Hardware
0 Ironhead in the uk
0 External breathing systems
0 Hi From Atlanta
0 Sportster Cobra seat
Last Post: duffy
2 My 1275 Hammer Conversion..
Last Post: Firehawk
0 H-D 2019 Financial Results
0 cam lobes
Last Post: Bow only
0 The B's Knees...
Last Post: shgrier
0 roadside belt change
0 77 XLCH oil line routing
0 Sleeve cylinders?
0 Hi from Spain!
0 Filling stock motor mounts with liquid urethane
77xlch, buell_fxr (74), Danny (63), Wino (51), no_chrome (45), USMC_Davii (43), dijitaldna (38), 08nightmare
cometic, gaskets, seals
Old 5th November 2009
kolmstead13 kolmstead13 is offline
Sportster/Buell Model: 883 sportster
kolmstead13 is an unknown quantity at this point
Default choosing gasket set
What's the difference between OE gasket set and a Cometic Gasket set. I had leaking from a number of place and I know 2 owners ago had this bike sitting in a shed for a while, hence the mileage ( 1994 with 3700 miles). So I figure I would just replace all the gaskets and seals. And it gives me something to do waiting for my led sled to get welded on. Any thoughts, suggestions, other gasket company to check out?
DEEP DIVER's Avatar
Sportster/Buell Year: 1984
Sportster/Buell Year #2: 1993
Other Motorcycle Year: 1984
Use James or Cometic, best way to go.
brimic's Avatar
brimic brimic is offline
Sportster/Buell Year: 1990
Other Motorcycle Model: Fxdwg
Other Motorcycle Year: 98
brimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the rough
The newer OEM gaskets are probably best for the rocker boxes (the new lower gasket will be 1-piece and orange in color) and the O-ring gaskets will fit perfectly. I've used both Cometic and OEM rocker box gaskets, the OEM are far better. For base/Head gaskets, Cometic are the best. Bottom end stuff, I really don't know
Edit: not entirely sure, but I've heard the James Rocker box gaskets are the same as the newer OEM.
TANSTAAFL
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
Similar....but I think the OEM lower rocker box gaskets are better. I do have James on there now and they aren't leaking....but the OEM ones looked better.
I am using the Cometic head gaskets though. I've only used the over-priced OEM bottom end gaskets though!
Stuff: YES
