2 My 1275 Hammer Conversion..
0 Sleeve cylinders?
0 Ironhead in the uk
0 Hi from Spain!
0 Hi From Atlanta
0 Sportster Cobra seat
Last Post: USAFpj
0 Filling stock motor mounts with liquid urethane
0 77 XLCH oil line routing
Last Post: nychopper
Last Post: Gospelman
0 External breathing systems
0 Banjo bolt sizes for front brake line.
Last Post: slamtry
5 Nightster tyre type "-" or "B"
Last Post: wally_m82a1
0 TC88A update ?
0 Too HOT to ride?
0 19'' Cast/Chrome Front Wheel
Last Post: SLW210
0 Show us the different versions of your bike!!
Last Post: lehel
0 roadside belt change
0 Early 60's headlight "brow", "mount", "visor" or whatever you want to call it.
Last Post: Blowupster
Last Post: corndog76
Taipan (61), Harveyveepower (60), regoscar (51), kmm0000 (45), SmokeyDrifter (37)
air, dies, fuel, power. loss
Old 27th February 2010
pearlblue pearlblue is offline
pearlblue is an unknown quantity at this point
Default 2004 883c power loss at 65 mph
VERY frustrating issue - any of you have it?? I have an '04 883C carbureted, and there is an intermittent total loss of power (air? fuel?) when decelerating from 70 to 60...it does not happen all the time.....sometimes the bike DIES altogether! Twenty seconds later it's fine. Scary when in the fast lane. Two dealers unable to solve - any XLForum readers know of/experience this??? THANKS! -pearlblue
Bspike1's Avatar
Bspike1 Bspike1 is offline
Sportster/Buell Model: 883C
Bspike1 is an unknown quantity at this point
I have the same bike and I have not heard of that issue. Good luck
FoxsterUK's Avatar
First thing I'd check is the battery leads. Very common thing for them to be loose and/or corroded and cause all kinds of problems similar to yours.
If you strip the leads off, clean up the contacts, refit but still have the problem then I'd take a look in the carb for gunge floating around the floatbowl or a sticking float. Just give it a good clean-out.
Fox
I had an '05 1200R.
OrangeR's Avatar
OrangeR OrangeR is offline
Sportster/Buell Model: XL883R
OrangeR has much to be proud ofOrangeR has much to be proud ofOrangeR has much to be proud ofOrangeR has much to be proud ofOrangeR has much to be proud ofOrangeR has much to be proud ofOrangeR has much to be proud ofOrangeR has much to be proud ofOrangeR has much to be proud ofOrangeR has much to be proud ofOrangeR has much to be proud of
+ 1 on what Foxy says, although one would hope that the 2 dealers you've visited already would have covered most of these options.
If you still can't find any faults I would take a look at your petcock especially if you still have the standard vacuum one. I personally don't like the vacuum petcock and have just changed mine.
I hope this helps,
OR........
Weo's Avatar
Weo Weo is offline
Sportster/Buell Model: 883-1250
Other Motorcycle Model: 600cc CBR
Other Motorcycle Year: 1987
Weo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to all
+2 on battery leads.
DO you have pigtails on for a trickle charger? I had issues with corrosion on their connection to the battery that caused strange problems on the highway. The screws appeared tight, but they were actually welded in because of the sparks the corrosion caused. After that I made sure I clean all connections to the battery with a wire brush and use a battery terminal protectant spray whenever I change my battery.
"Insert witty comment here" -1999 883-1250 XL, N4 cams, NRHS AC, ST 2-1, Golan petcock, Ricor Intiminators, aesthetic changes
Porky's Avatar
Porky Porky is offline
Sportster/Buell Model: 883 Roadster
Porky is an unknown quantity at this point
It sounds like a fuel problem to me. Your main jet may be blocked by a piece of dirt or old gasket material. It can be sucked up and plug things completely, usually under full power and maximum suction, close off fuel and then when you let off of the throttle, with less demand, the foreign object drops down into the float bowl---ready to attack again and cut off your fuel supply!
Check the fuel petcock filter also as they can become dirty too.
Sam
2005 883R, 2009 T-max, 2009 Buell 1125CR, 2010 Triumph scrambler.
deonc's Avatar
deonc deonc is offline
Other Motorcycle Model: Yamaha TZR 125 Race Bike
deonc has disabled reputation
Crank position sensor... Spare yourself a lot of scratching around on the carb and check that out first. There is a sticky on this on the forum.
Deon Cilliers
Cape Town, South Africa
2006 883 Roadster
"Taxes Paid"
FoxsterUK's Avatar
Could be. Didn't sound quite like the usual symptoms but
