0 Well this just went south.
Last Post: wolfryder
0 Hello from Florida!
0 1983 Ironhead - Oil not Returning
0 Anne
Last Post: allcatjazz
4 nouveau sur le site
Last Post: yelladox
0 Rubbermount Poll
Last Post: WarlordATF
0 Intake Gasket Conversion?
0 Drain plug thread size
0 Easy question (i think) re: Voltage at Switch
0 No mas on the starting issue
0 Old man having a little fun. Opinions please. Porn.
Last Post: tygr1
1 Help required for Motogadgeting all the Things
0 Bigger Rotors on Stock Calipers?
0 1979 Ironhead Relay mounting hardware
Last Post: ThenCameHarry
0 Cleaning carbon build-up
0 More Stroker Parts
0 Power loss
Last Post: Fivecats
3 Setting The Ignition Timing on Your IronHead
Last Post: mgentry66
0 74xlch
0 New handlebars for 2017 XL1200C
Last Post: JRRadtke
0 A different Oil filter test
Last Post: ivanford
obinella (79), bathscum2 (69), XL883 (69), sammyson (67), mrscantolina (56), colonelangus (56), 5oh (53), black051200 (48), garagechoppe (48)
Old 29th June 2020
Heff's Avatar
Heff Heff is offline
Sportster/Buell Model: Xlh
Heff has much to be proud ofHeff has much to be proud ofHeff has much to be proud ofHeff has much to be proud ofHeff has much to be proud ofHeff has much to be proud ofHeff has much to be proud ofHeff has much to be proud ofHeff has much to be proud ofHeff has much to be proud ofHeff has much to be proud of
Default Main shaft bearing preferences
6207 bearing. Many options, as far as shields go.
What works best? Im (over)thinking a shield on the primary side, open on the inside of the transmission, that would keep the bearing somewhat lubricated. Or just a get a bearing and go with it?
72 xlch
Old 29th June 2020
Over thinking....
I would not get a sealed bearing, Shields keep oil in the bearing, open allows it to drain.
Old 29th June 2020
Heff's Avatar
I really over think these kinds of things.
I'll just get a good quality bearing, press it in, and go on with the project.
Old 1st July 2020
ferretface's Avatar
The m/s bearing that came out of my '83 had shields. Looked OEM. Whole primary/trans looked untouched since new [14+K miles]. My thinking is that H-D must have had a reason to put shields on it. Shields cost extra. Doesn't mean it was a good reason, however.
Old 1st July 2020
doodah man's Avatar
An old post from doc dick said the trap door big bearing should have at least the clutch side shield in place to keep the kicker gear ratchet spring out of the ball bearings. Apparently the other side is optional. I’ve never had issues with having both shields in place.
Old 1st July 2020
bearings run hotter when flooded with oil,believe it or not.
Old 2nd July 2020
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
Bearings don't much like dirt, grit and other odd bits of debris.
With all of the mating rotating surfaces inside a gearbox you will always get some "stuff" floating around inside there.
The primary side is worse.
But I still suspect it just comes down yo what you have on hand or what you prefer/believe.
Old 4th July 2020
Heff's Avatar
Ended up using a nos fafnir bearing, shielded on clutch side, open on transmission side. Installed a new cs roller bearing while I was doing things. Should be ready to go for a few miles
Old 4th July 2020
it came with one shield removed?
Old 5th July 2020
Blind Owl
They do supply single side shield bearings.
On the part number most manufacturers us an S or a Z. SS id double sided S one side only. ZZ is double sided metal shield.
