Last Post: Traxx
0 Hello New to the Forum
0 Another ultima iggy query.
Last Post: Randy_rots
0 Tour of Honor
Last Post: Traxx
0 My 1250 to 1275 build
Last Post: Bryan1976
0 battery drain
0 Stock vs. Modified
0 Sportster runs only on choke
Last Post: v3ko123
0 Headlight - What are you using ? - '74 XLH
Last Post: Serious Blac
0 New to us
0 Range With EFI 4.5 Gal Tank
0 I guess I'm back
0 after conversions, do have oil consumption problems?
Last Post: xllent01
0 New rider, first ride
Last Post: Testostebro
0 67 to 70 cam cover and sprocket cover.
Last Post: farmall
0 Rear brake issue
Last Post: xraytoken
0 Here goes...
Last Post: oreocat1
0 Hello!!!
Last Post: oreocat1
Last Post: clif02
0 hello and help!
Last Post: Blairjesse
0 Superbrace vs RSD Fork Brace
0 newbie
Last Post: oreocat1
0 2001 motor in 1987 frame?
0 Happy Birthday Joebobber
5 Vacuum petcock questions...
0 My 1988 basket case has a belt? Should I keep it?
Last Post: farmall
PlanB, Cuco6924 (73), 1200sporty (62), iron68 (48), LifesHarlequin (35), mattosm (34)
  #61
Old 10th May 2019
DollarBil's Avatar
DollarBil DollarBil is offline
DollarBil has a spectacular aura aboutDollarBil has a spectacular aura aboutDollarBil has a spectacular aura aboutDollarBil has a spectacular aura aboutDollarBil has a spectacular aura aboutDollarBil has a spectacular aura aboutDollarBil has a spectacular aura aboutDollarBil has a spectacular aura aboutDollarBil has a spectacular aura aboutDollarBil has a spectacular aura aboutDollarBil has a spectacular aura about
I like where you went with the seat. I wish I would have seen it before. I got the brakes hooked up last night. Still have to do oil lines and wiring and many small things. Let's stay in touch.
Rubber side down...
Old 10th May 2019
DollarBil's Avatar
Originally Posted by RökkenRöll View Post
It will sit just behind the down post. That mount has to be welded on still, and I have to make a battery box. I'll do that and sort out the front while everything is gone for paint.
1989 XLH1200
I didn't have my chain on when I built my battery box,[IMG][/IMG] so it was interfering. The next pic you see I will have relocated the battery box and reversed the mounting of the oil tank... and made a chain roller to keep it from hitting the oil tank. The motor was too big to put it in front of the down tube.
Old 10th May 2019
Air-Cooled Forever
RokkenRoll: I was wondering if your oil tank should be between the fender and frame instead of between the engine and frame. It looks like it may interfere with the rear exhaust pipe.
Old 15th May 2019
RökkenRöll's Avatar
RökkenRöll RökkenRöll is offline
Sportster/Buell Year: 1989
RökkenRöll is a name known to allRökkenRöll is a name known to allRökkenRöll is a name known to allRökkenRöll is a name known to allRökkenRöll is a name known to allRökkenRöll is a name known to allRökkenRöll is a name known to allRökkenRöll is a name known to allRökkenRöll is a name known to allRökkenRöll is a name known to allRökkenRöll is a name known to all
That took a lot of back and forth to figure out, original plan was King and Queen, but custom seat prices combined with lack of an available commercial option I looked led me to this one which he on me a lot then ended up getting it. Sorry to hear about the battery box, that's a pain in the ass. I'm just sending mine off for powder coat tomorrow.
1989 XLH1200
Old 15th May 2019
RökkenRöll's Avatar
Mocked it up with the exhaust, the angle of that pipe is quite sharp so it fits with a good amount of space. Thanks for the thought though.
1989 XLH1200
Old 15th May 2019
RökkenRöll's Avatar
Most recent photo I took. It's all back apart again for powder coat, but this at least gave me an opportunity to feel like I've made progress. TC Bros narrow Frisco tank, 6" over forks, TcBros oil tank, sissy bar, and heavily modified fender. Seat is the Le Pera signature 2 in a diamond stitch. Still work to be done polishing the forks after removing the tabs, then cleaning up and polishing the triple trees. Tank I'm getting painted but then before it gets the clear coat I'm doing some gold leaf on it, so we'll see how that goes. Has anyone used the antigravity batteries before?
1989 XLH1200
Old 16th May 2019
DollarBil's Avatar
I used the little orange Ballistic battery on my last Bob. worked good. I had no room for a full size.
https://www.bikebandit.com/blog/lith...ycle-batteries
Old 16th May 2019
Cmd11's Avatar
Cmd11 Cmd11 is offline
Sportster/Buell Model: Xl 883 c
Sportster/Buell Year: 06
Cmd11 is an unknown quantity at this point
Bike looks good hope you get to ride it soon
Old 16th May 2019
Cmd11's Avatar
Originally Posted by Desertfox View Post
I can't believe you want to chop this beautiful machine up into a worthless unridable piece of junk.
Choppers are unridable pieces of junk. Second off you didn’t buy it so let him do what he wants to his bike. Harley’s are meant to be customized to the owners liking highly disrespectful for you to say that to someone
Old 31st May 2019
RökkenRöll's Avatar
Coming along! One day at a time. Getting to the part that worries me... Wiring and plumbing...
1989 XLH1200
