Last Post: Lone Rider
0 derby cover leak
0 Ign coil
Last Post: mac93
Last Post: DirtyHarry68
0 New Gas Tank or Cat Litter Jug.
Last Post: broknluck
0 Who Runs Turn Signals?
Last Post: Traxx
0 Will Dyna switchback shocks work on a sportster?
0 1967 Harley Sprint SS250
Last Post: Crash7557
0 2 Questions - LED Turns and Front brake light Sw on 1978 XLH
0 Never seen this before...
0 Posting pics
Last Post: Yellowstone Kelly
0 75 XLH Electrical problem - Accessory Circuit
Last Post: Sprtstr1200s
10 how low do you let it idle
Last Post: JacksBrother
0 Another Sporty ADV Build
Last Post: MotoVagabond
0 Nightster front turn signal
Last Post: Traxx
Last Post: hhugger
0 1969 XLCH Speedo
Last Post: Magneto Sportster
0 what size battery is appropriate?
Last Post: smac74
SHAKY DAVE's Avatar
SHAKY DAVE SHAKY DAVE is offline
Sportster/Buell Model: XLX
Sportster/Buell Year: 83
Sportster/Buell Year #2: xlh
SHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to all
Default Quick Question (Tach Wiring)
got a late ironhead factory tach for my '85 race bike.not using the light so its gone.ultima says pink wire goes to center of coil,blacks a ground.wheres the orange wire go?even my factory service manuel is way confusing.thanks
Here's the Sportsterpedia section on Minimized Ironhead Wiring:
http://sportsterpedia.com/doku.php/techtalk:ref:elec07
It has a configuration diagram & description for using an Ultima Ignition.
Harley ORANGE wire is usually key-operated Power from a fuse.
Harley PINK wire is usually coil trigger & Tach Signal to Tach.
Harley BLACK wire is usually Ground.
For Dual-Fire Ultima Config:
Ultima PINK wire is trigger for dual-fire coil.
Ultima GREEN wire is Tach Signal to Tach.
Ultima body itself is grounded in the nosecone.
For Single-Fire Ultima Config:
Ultima BLUE wire is front coil trigger.
Ultima PINK wire is rear coil trigger.
Your Tach will need to be grounded to the frame/battery somewhere.
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
The correct question is not where the orange wire goes to, but where it comes from Every orange wire on the bike, including this one, comes from the ACC circuit breaker. That is 12 volts when the key is on.
There is [was] an "orange wire connector" in the headlight bucket. In the FSM diagram, there is one wire going in [left side of pic, lower]. there is one wire that simply loops [right side, upper], and two more that are outputs.
We leave it as "an exercise for the student" to figure out why the loop is there. There is a reason for it.
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
SHAKY DAVE's Avatar
out of the tach is 3 wire,pink,black and orange.single fire ultima,black is ground,pink is coil so I guess orange is power off the switch.no factory wiring on the bike anywhere.ground up build a few years ago,nothin in the headlight body.went off my factory service manual when I wired it.absolutely no electrical problems,ever.been thinkin about wiring my street bike completely,get rid of the crap inside the bucket.maybe this winter.thanks
Tach PINK Wire --- Connect to the Ultima GREEN Wire (Tach Signal)
Tach ORANGE ----- Connect to a Fuse that has keyswitched power
Tach BLACK ------- Connect to any frame/battery ground
SHAKY DAVE's Avatar
thanksthats what I figured
