Last Post: Lone Rider
0 derby cover leak
0 Ign coil
Last Post: mac93
Last Post: DirtyHarry68
0 New Gas Tank or Cat Litter Jug.
Last Post: broknluck
0 Who Runs Turn Signals?
Last Post: Traxx
0 Will Dyna switchback shocks work on a sportster?
0 1967 Harley Sprint SS250
Last Post: Crash7557
0 2 Questions - LED Turns and Front brake light Sw on 1978 XLH
0 Never seen this before...
0 Posting pics
Last Post: Yellowstone Kelly
0 75 XLH Electrical problem - Accessory Circuit
Last Post: Sprtstr1200s
10 how low do you let it idle
Last Post: JacksBrother
0 Another Sporty ADV Build
Last Post: MotoVagabond
0 Nightster front turn signal
Last Post: Traxx
Last Post: hhugger
0 1969 XLCH Speedo
Last Post: Magneto Sportster
0 what size battery is appropriate?
Last Post: smac74
T. Clark's Avatar
T. Clark T. Clark is offline
Sportster/Buell Model: XLS
Sportster/Buell Year: 1983
T. Clark has much to be proud ofT. Clark has much to be proud ofT. Clark has much to be proud ofT. Clark has much to be proud ofT. Clark has much to be proud ofT. Clark has much to be proud ofT. Clark has much to be proud ofT. Clark has much to be proud ofT. Clark has much to be proud ofT. Clark has much to be proud ofT. Clark has much to be proud of
The standard front wheel off my 83 used to leak like a sieve, would have to add air every few days. Ended up scuffing up the inside of the rim and hitting it with a polyurethane primer. Problem solved. Maybe the Morris will leak, maybe it won't, only one way to find out but it won't hurt to sand and paint just in case. Seems quite a few bike brands had problems with porous wheels. All good when new but start to leak over time, all things ironhead are positively ancient now.
