0 Engine light
0 Chevelle's Dry Clutch Worm Gear Upgrade
0 connecting rod bearings
0 Putting the Sport back in the Sportster
14 What made the best Improvement to your Sporty??
0 BEWARE Of SCAMMERS!
0 Free - Heel/Toe shifter from my 95 (should fit 86-03?)
Last Post: Brad
0 Installing Thunder Torque Inserts™ - More Torque - Deeper Tone - Dyno Proven
0 Through The Years
0 Premium Performance Rear Shocks - More Range of Adjustability
0 Simple 883 to 1200 Conversion?
0 Hey Yall
0 Chain: What Type?
Last Post: Captain Johnny
0 What's Wrong With My Bike
Last Post: joe s
0 LSL Flat Track bars question for 2021 sportster 48.
Last Post: edharley48
0 2021 Harley Sportster 48 Rear brake pad replacement question
0 e bay deals i got past 2 weeks
Last Post: Monte03
0 Latest toy arrived... 1967 Sportster XLB
Last Post: thefrenchowl
0 Pipes "Wheezing" on decel
0 shovster ignition timing
bsczar1 (52), slomo (49), jasonmrenda (48), bishop109 (47), PhatE60 (42), jshbs40 (39), tanktiger52 (26)
stentis's Avatar
stentis stentis is offline
Sportster/Buell Year: 1971
stentis is an unknown quantity at this point
Default Need new steering stem
1972 Sportster custom build chopper.
I picked up a girder front end and the steering stem is gone. The ape who had it before me tried to fix everything with a hammer, he also did not know about using a press. The lower tree needs to be machined.
I really need the steering stem dimensions on a schematic of both 1 inch and 7/8 inch so I can machine another stem.
Tim The Grim's Avatar
MetalWorkingXLFan
Sportster/Buell Model #2: KHK
Sportster/Buell Year #2: 1954
Other Motorcycle Year: 97
It’s a girder. The pivot arm point distance on the forks denotes the distance you need to have between the pivots on the trees. That usually involves some spacers to get things nice and equal. Get that thought out and then machine your stem to work with your choice of cups and bearings.
I kinda prefer the balls with tube forks but on heavier forks like girders that may jangle around more I go with Timken type.
Andy Hog's Avatar
Andy Hog Andy Hog is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: 1964 Triumph 3TA
Andy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant future
Hmmm.
If you already have the round bar you are going to machine why don't you pop on a tapered roller bearing to it, place the cup in the bottom neck of the frame, put the other bearing in the top off the neck with the cup, put the bar through the neck, offer up the bottom & top yolks, measure the length required & machine to that size?
stentis's Avatar
Default Steering stem
I don't have an older Sportster to measure the neck. I live in a small community next to a reservation. I need the measurements/drawing of the the stem or the stock length. I know the stem fits other bikes.
Thank you for your reply
