Last Post: JacksBrother
0 Worst Harley rider ever.
Last Post: crazyphuzz
0 Lots of issues 78
Last Post: Mrhorn12
0 New to the Harley Brand
0 What's your helmet?
0 Yetman drag frame
Last Post: Slojoe55
0 C.O.B.B run west
Last Post: Yakcm2
0 Shovester Sighting
0 1998 Sportster Ignition Problems
Last Post: james69
0 Starter circuit without relay
Last Post: ChicagoSlim
Last Post: kk38k
0 I finally learned how to work the system!
Last Post: Ranchero50
0 Broken exhaust stud questions.
0 What coil(s) do you run with your Dyna S ignition?
Last Post: stanroyal
0 Carb
0 Issue until up to temp
0 1981 XLH turns over won’t start
5 Legendary Jerry Branch on Gearing quote and question...
Last Post: groovemeisterus
0 77 idling
Last Post: fbroos73
6 Asgardia Regional area
0 Sportsterpedia Progress
0 Show us your bike next to a Water Tower.
Will1250 Will1250 is offline
Sportster/Buell Model: XL
Sportster/Buell Model #2: XL 1200 bitsa project
Sportster/Buell Year #2: 1986
Will1250 has much to be proud ofWill1250 has much to be proud ofWill1250 has much to be proud ofWill1250 has much to be proud ofWill1250 has much to be proud ofWill1250 has much to be proud ofWill1250 has much to be proud ofWill1250 has much to be proud ofWill1250 has much to be proud ofWill1250 has much to be proud ofWill1250 has much to be proud of
Default Right Angle Plug Caps and Leads
Hey boys and girls, is there a quick swap with any other model so I can have right angle plug caps and leads for a 2004 rubbermount?
I understand with suppressed leads one cannot just pull the straight plug caps off and substitute right angle ones without compromising reliability.
TIA, Will
rocketmangb's Avatar
Look here,you should be able to get any style you want !
http://www.sumax.com/plug_wire_overview.html
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Thanx for that site sir.
Though postage to Australia was more than the actual cost of a set of leads I did order a set.
Cheers, Will
