0 Powerraythor conversion
0 Timing
Last Post: mickey t
Last Post: staniel
0 P0505 code on my '09 XL883C driving me insane!!
0 gas cap
0 What weight oil?
0 blonde, brunette, red?
Last Post: Lincoln
Last Post: SLW210
Last Post: Edwinblake
0 TMC Dumont motorcycle concept
Last Post: Brad
0 Not an ironhead, but....
Last Post: randy3934
Last Post: jcn59
0 Cable lengths
Last Post: xElvis
Last Post: Gulf Coaster
0 2011 1200C tuner?
Last Post: ktp1598
1975, grey, ironhead, sportster
Old 26th October 2017
Is the rear fender original? or has that hump for the license plate been molded in by a PO?
Note that there are no turn signals. I have seen one bike locally where the PO simply cut the wires. It was OK [not good, just OK] for a while then it started to have electrical problems. The cause of course was the cut wires grounding out on the handle bars in the switch housing, and under the rear fender. Best to check this out.
doodah man's Avatar
Originally Posted by Runhan90 View Post
There is some leakage with the bolt underneath. The guy who imported it runs a Car-import business and dosent know much about bikes, so all info I got was some info from the previous owner. And that wasnt much.. But here is a photo from underneath
oops, totally forgot that i commented on this pic in another thread of yours!
Runhan90 Runhan90 is offline
Sportster/Buell Model: Xlh1000
Runhan90 will become famous soon enoughRunhan90 will become famous soon enoughRunhan90 will become famous soon enoughRunhan90 will become famous soon enoughRunhan90 will become famous soon enoughRunhan90 will become famous soon enoughRunhan90 will become famous soon enough
Originally Posted by 45Brit View Post
Looks like a basically very original bike. Does it have good frame numbers? I can’t make any out on the pictures, but they are quite low-resolution.
Non-original parts include exhaust, seat, rear mudguard and struts, handlebars. Carb appears to be an S&S? Lockhart (?) oil cooler is a common period accessory. Braided oil lines are common accessories.
Instruments should be the plastic speedo and rev counter mounted on the handlebars. Bike would originally have had indicators on the handlebars and rear mudguard struts and the big “cowbell” horn on the left side of the engine.
Left-side crossover linkage gearchange is an acquired taste, I thought the shift action on mine was horrible and I am in the process of converting to right shift (this is fairly straightforward on 75-76 bikes)
Nice, though...
It got matching numbers. The frame number is a bit hard to read on the pictures, but it matches. Ooh, hopefully I dont have to convert.. Is it expensive parts?
45Brit 45Brit is offline
Sportster/Buell Model: XL
Sportster/Buell Model #2: 1978 XLCH project
Other Motorcycle Year: 1975
45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute45Brit has a reputation beyond repute
Good matching numbers are a big plus.
Conversion to right side shift is straightforward on 75-76 bikes and the parts are easily available, but it means a lot of dismantling and reassembly, and bench drilling/pressing facilities. 77 onward bikes are a different matter entirely.
There is a thread on here discussing this, also including a much simpler re-engineering of the linkage at the right side, which looks as though it ought to improve matters and doesn’t require the transmission to be disturbed. The Harley linkage is pretty crude, after all.
Then again, some people don’t find these bikes a problem. Ride it and see.
Yeah guess i just have to try it out. Good to know in case its crap thouh!
I suspect that over the years most -75 and -76 owners have not done the shifter conversion. Most likely when you find the best adjustment procedure it will be satisfactory.
I have not had one of these myself but I do recall some discussion of the best adjustment procedure on this forum. Found it in the Stickys...
1975, 1976 gear shift fix
http://xlforum.net/forums/s....php?p=3376550
Old 27th October 2017
Darkseacret Darkseacret is offline
Sportster/Buell Year: 77
Darkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to all
Nice looking sporty . Clean and mean
Old 28th October 2017
valvebeater valvebeater is offline
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1975
Other Motorcycle Model: FLH
Other Motorcycle Year: '82
valvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of light
I checked out this old thread. Says I cant open the photos until I upgrade photobucket for 3rd party hosting, fee is $399 annualy, WTF?
photobucket fix
http://xlforum.net/forums/s....php?t=2042791
Check out this link:
http://www.xlforum.net/vbportal/foru....php?t=2042791
