Last Post: 1Scooter
0 supply and demand
Last Post: thefrenchowl
0 Which Brake Setup To Use?
0 Speedo cable hunt
Last Post: fafcpa
0 Ran out of gas.
Last Post: Dusz
Last Post: Dusz
0 Сar depreciation
Last Post: Fivecats
Last Post: Kingrabbit
0 Oil leak from engine bolt?
6 SPORTY BOBBER PICTURES
Last Post: Bigshankhank
Last Post: bplinson
Last Post: bplinson
0 Ebay vlovkling International bidding ?
0 73 XLCH help
Last Post: Doc308
0 New to Buell S2T
8 Barnett clutch plates
Last Post: BrianS
Last Post: Lone Rider
longrun-pa (73), goose59 (64), Stumble (59), Rowdy65 (58), peten (57), roderash (56), flightmedic (54), sportster steve (53), buscuit88 (35)
  #41
conv90's Avatar
conv90 conv90 is offline
Sportster/Buell Year: 1990
Sportster/Buell Model #2: Sportster
Sportster/Buell Year #2: 1975
Other Motorcycle Model: Buell S1 W
Other Motorcycle Year: 1998
conv90 has a reputation beyond reputeconv90 has a reputation beyond reputeconv90 has a reputation beyond reputeconv90 has a reputation beyond reputeconv90 has a reputation beyond reputeconv90 has a reputation beyond reputeconv90 has a reputation beyond reputeconv90 has a reputation beyond reputeconv90 has a reputation beyond reputeconv90 has a reputation beyond reputeconv90 has a reputation beyond repute
Originally Posted by delcrossv View Post
Yep. The shorter cylinders of the S&S version meant short piston skirts.
This one is taller.
For what I know the S&S 100 (4x4) preassembled engines are with 4.420" cylinders (shorter than stock 4.650" height). Probably the S&S case in these preassembled engines are taller cylinder deck height.
Which is the deck height of your S&S case project?
1990 Sportster Axtell 90 ci, CP Carrillo 3.875 30° deg pistons,STD Heads, 615V2 RedShift cams, HSR48,
Carrillo 6.938 rods (All HammerPerf)
Hammer Billet Sledge air filter
Hammer Billet Manifold.
160/60ZR17 rear on Akront 5.50" Alu rim
100/90-19 front on Akront 2.50" new Alu rim
YSS 13.75 rear shocks
1975 XLH almost stock
1998 Buell S1W almost stock
delcrossv delcrossv is offline
Sportster/Buell Model: XL Sportster
delcrossv is an unknown quantity at this point
I had it somewhere, but the cases are at the machinist's. I do know the cylinders will be longer than stock, and the Jesel rockerboxes are taller as well.
I'd be very surprised if it fit without raising the backbone, and have no expectations that it will.
Running some numbers.
Finally CC'd the heads and got dome volume off the pistons.
With .040 squish (assumed)
Static compression is 13.6:1
Dynamic is 12.6:1 with big overlap cams (Redshift 723V2's)
Looks like this one is going to run E85 (alcohol) -fortunately available pretty much everywhere around here.
Should get a good power boost as stoich is around 8:1 for E85 as compared to 14.7:1 for gas. Wheee!
Cranking compression is 289 psi. Probably should start thinking about compression releases.
