Last Post: Brendenhrvy
0 Ebay vlovkling International bidding ?
0 Oil leak from engine bolt?
Last Post: skittlenips
0 Сar depreciation
0 supply and demand
0 73 XLCH help
Last Post: Doc308
0 Which Brake Setup To Use?
Last Post: SkyDiveBlack
Last Post: bill smith
0 New to Buell S2T
8 Barnett clutch plates
Last Post: BrianS
Last Post: Lone Rider
0 Will this fit a 2022 sportster?
0 Paint exhaust headers?
0 Seneca Shadows WV. Sept. 5th to 8th and maybe beyond.
0 Ran out of gas.
0 Good grief...
Last Post: FrameMount1200
0 1983 Ironhead! No Spark
0 Why cafe a sportster?
mikuni vm38
He probably has the idle set wrong because it works backwards from other carbs.
Sportster/Buell Year #2: '03
^^ thanks for re-mentioning that.i should go back and turn that screw back in a bit.
72 1000cc barrels and XLR heads, S&S 4-1/2'' flywheels, sifton minus-minus cams, S&S super A w/ zippers thunderjet w/yost powertube, Andrews gears,and shafts, 72 oil pump, Morris magneto w/auto advance and single fire module, cycle electric generator w/electronic regulator,73 cu.in.
kitabel kitabel is offline
Sportster/Buell Year: 1989
No matter which way it turns, you're looking for the best, highest idle quality
^^^ i had it there,and wanted to end up on a tad richer.
Ferrous Head's Avatar
Sportster/Buell Year #2: 1966
Screwing things doesn't always make you richer.
You could lose your house.
Doc308 Doc308 is offline
Sportster/Buell Year: 1969
Other Motorcycle Model: Softail Slim
Other Motorcycle Year: 2016
Doc308 is a splendid one to beholdDoc308 is a splendid one to beholdDoc308 is a splendid one to beholdDoc308 is a splendid one to beholdDoc308 is a splendid one to beholdDoc308 is a splendid one to beholdDoc308 is a splendid one to beholdDoc308 is a splendid one to beholdDoc308 is a splendid one to beholdDoc308 is a splendid one to beholdDoc308 is a splendid one to behold
I'd bet that the straight trough pipes are a factor here. In tuning the VM-9, the engine needs to be completely warmed up and , starting with the idle, you want a setting between bogging down and missing when revving. If you get hesitation when revving , you're on the lean side. Very gradually richen the idle mixture screw vvery small increments at a time. Once that it set up, take it out and see how the intermediate setting is--same deal: hesitaton means lean; bogging means rich. Then, move the clip on the needle jet in whatever direction smooths out the issue. I run VM-9's on all of my old Harleys--have for 50 years and I love them. As mentioned, te straight pipes may be the issue here.
Doc 306 : I run VM-9's on all of my old Harleys--have for 50 years and I love them.
And here's the thing. Exactly why I don't like them. It's not hard when you've spent 50 years tuning engines, all kinds of engines. But for inexperienced people they are a lot more difficult to get right. They are not as forgiving as a Super B.
All of this assumes that he actually has a VM38-9.
Until he opens it up, he doesn't know what he has. Some of the other jetting specs will be so far off the bike cannot be ridden.
Hint: there are also VM38-1, -2, -3...
Old 6 Days Ago
rejeanprimeau's Avatar
The first two numbers are throat size and the / or - number is the flavour. VM38/21 are made for snowmobile. Might work but too many ?????
Follow manufacturer recommendation, oups, we are mostly men here and don't or never find them in the box or garbage can.
Old 6 Days Ago
sungod's Avatar
sungod sungod is offline
Sportster/Buell Year: 1970
Sportster/Buell Year #2: 1973
+1
Whitewalls posted a VM38-9 sold by MOTOCARB UK that has a 40 pilot jet.
Other sellers like OZ and Sudco come with a 30 pilot jet.
