0 1968 xlch
Last Post: Moon Wolf
Last Post: jharback
0 2-1 Header Pipes
0 A thank you
0 Seized Oil Pump
0 Flat Tire
Last Post: oupa
0 Motorcycle cafe suggestions
Last Post: oupa
0 compression problems
0 Cafe or sport faing on xl1200cx?
Last Post: noxlyet
Last Post: Bwf347
9 Been a long time! !
Last Post: Texassporty06
0 Wanted: Sportster mid controls
Last Post: racemoto
0 Finding a new doctor...
Last Post: Wilkinson949
Last Post: Akdawg
4 The no-debate OIL POLL
Last Post: Jarlaxle
0 Forum problems???
Last Post: oupa
Last Post: hawgford
0 Motorcycle Events
Last Post: rhartlin
0 Bendix / Zenith questions
Last Post: hawgford
Old 10th September 2018
Grumpy-Biker's Avatar
Grumpy-Biker Grumpy-Biker is offline
Sportster/Buell Model: Custom 883
Grumpy-Biker has disabled reputation
Okay So I took the rockers off, everything was tight, opened the cam chest, cleaned all the oil passage . Oil cooler reinstalled, prime the oil pump and got oil to come out the oil cooler. Button everything up and after 10 minutes ride the slight knocking started again.
Since I was up the street I nursed it back home.
I thought may it could be coming from the primary. So I checked the chain and it was really tight no play. So I adjusted it and went down the alley and the knock was worse.
Took the primary cover off to check everything. Well the clutch is burnt.
So I'm putting a new clutch pack in. I'll know if that was it.
What are the odds that the noise would start just when I was installing the oil cooler??
Maybe I did not inspect and clean the basket enough after the Plate fell apart with all the bright rivets. I took the time to file off and polish all the little groves.
Clutch should be in a few days, I'll keep you guys poste.
j
rocketmangb's Avatar
Shit,my plate blew up so i replaced the clutch pack,week later the stator died !
Looked like maybe a piece of spring or rivet shorted the stator !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 23rd September 2018
Well New clutch and the noise is worst than ever. Only rode it 50 yards and shut it down.
While I had it apart for the clutch I had taken the spark plug out there is no noise in the cylinders. It sure sound like it is the crank. The only way to know is to split the Case.
This may have gone on for a long time, causing other issue like heat and lost of power i'm guessing and now the crank is only completely failing so you can hear it. Noise is very similar to vid from another thread.
Time to investigate.
Bored now Bored now is offline
Sportster/Buell Model: 883
Bored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond reputeBored now has a reputation beyond repute
The 04 and 05s did have issues with the cranks, it is usually the front rod that fails on the big end. No need to split the cases to check, just pull the cylinder and check the rod for up and down movement, there should be none.
Old 24th September 2018
Thanks Bored I will start there.
