0 Thread revival
Last Post: gusm2
Last Post: Jcolleyoh
Last Post: Billy1200
0 Bendix insulator block
Last Post: JonesL
Last Post: simonster123
0 Black jugs matter
0 1968 xlch
Last Post: Hellbent_4
0 Intermittent electrical problem
Last Post: LLOYD883
14 2000 Front turn signal relocation kit INSTALL
Last Post: Akdawg
Last Post: Woody9225
0 THE Hockey Thread
0 Removing oil tank DIY?
0 Ignition advice
0 Speedo/Turns signals/Brake light dont work
Last Post: Joe_jeep
0 Why cafe a sportster?
Last Post: Merch131ho
0 show me your sporty next to an old or rural post office
0 Adaptive headlight issues
0 Post Your Seat Pics Here !!!
0 High idle code P0505
Last Post: dayypete
0 Range to Empty jumps and is on LR most of the time
Last Post: Blacklace
0 Easy Brackets on 93 Sporty
lathehand's Avatar
lathehand lathehand is offline
Sportster/Buell Model: 1000 xl 4 speed
Sportster/Buell Year: 1983
Other Motorcycle Model: 1994 FXDL
lathehand is an unknown quantity at this point
Default Another lubrications question
Hello folks Glad to be back been away several years.My 83 Ironhead hasn’t been started in quit some time now.It was just serviced before I went away Now when I looked it all over I found no oil in the oil tank and I know it bib that leak out.So I’m thinking it pooled into the crankcase. If that’s so what should I do to circulate the oil before starting her up against
Tipofthelake Tipofthelake is offline
Sportster/Buell Model: XLS 1000
Sportster/Buell Year: 1979
Sportster/Buell Year #2: 1973
Other Motorcycle Model: Electraglide
Other Motorcycle Year: 2007
Tipofthelake is just really niceTipofthelake is just really niceTipofthelake is just really niceTipofthelake is just really niceTipofthelake is just really niceTipofthelake is just really niceTipofthelake is just really niceTipofthelake is just really niceTipofthelake is just really niceTipofthelake is just really niceTipofthelake is just really nice
If quite some time is like a year or something I like to put a few mls of oil in each cylinder and rock it around a bit. After that leave the gas off, could even pull the plugs if you want, and then cycle the starter a few times. Regardless, put a catch pan under your vent line and prepare to have it spit out some oil when it gets going. Put the pan underneath BEFORE you mess with cranking or starting it unless you really like cleaning it up. (not that I have done that or anything...)
lathehand's Avatar
Quite some time is just under six years .I appreciate your your thoughts.I just don’t want to start it up without any oil circulation.Befoe I went away The engine was all redone and I don’t want to ruin it.
shanneba shanneba is offline
Cranking it for a minute (~15 seconds at a time, letting the starter cool between) should return about a 3/4 to 1 quart of the oil to the tank.
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
