Last Post: Jcolleyoh
Last Post: Billy1200
0 Bendix insulator block
Last Post: JonesL
Last Post: H.E.L.M
Last Post: simonster123
0 Black jugs matter
0 1968 xlch
Last Post: Hellbent_4
0 Intermittent electrical problem
Last Post: LLOYD883
14 2000 Front turn signal relocation kit INSTALL
Last Post: Akdawg
Last Post: Woody9225
0 THE Hockey Thread
0 Removing oil tank DIY?
0 Ignition advice
0 Speedo/Turns signals/Brake light dont work
Last Post: Joe_jeep
0 Why cafe a sportster?
Last Post: Merch131ho
0 show me your sporty next to an old or rural post office
0 Adaptive headlight issues
0 Post Your Seat Pics Here !!!
0 High idle code P0505
Last Post: dayypete
0 Range to Empty jumps and is on LR most of the time
Last Post: Blacklace
0 Easy Brackets on 93 Sporty
10 EFI - how to get the harley potato sound [HOW TO]
Last Post: Joe_jeep
rocketmangb's Avatar
If the jet on the left is indeed Dyno Jet it should be 5 MM where the Keihin will be 6 MM
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
kitabel kitabel is offline
Sportster/Buell Year: 1989
kitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to behold
There are 2 different Mikuni 5mm threads.
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Model: XL883
Sportster/Buell Year #2: 1999
We get that complaint periodically ... "The main jet you sent doesn't fit!"
Every single time, it's been because the carb has a non-stock emulsion tube. Usually a Dynojet kit. The customer bought the bike used and didn't know.
Click Here to Contact Me
Folkie Folkie is offline
That's odd, because M5 threads are normally 0.8 mm (coarse) or 0.5 mm (fine).
That's what I thought.
awright2009 awright2009 is offline
awright2009 is an unknown quantity at this point
Well CV-Performance opened up ordering again, so I ordered both jets and an emulsion tube from them, a bit pricey with shipping, but I’m sure long term it’ll be nice having two tubes
Sportster/Buell Year: 1991
If you have a Dynojet emulsion tube you might have a Dynojet needle as well. Might want to take a look so you can order a CVP needle to go with other parts.
John
I don't doubt this at all - Dynojet kits were popular alterations to the CV40 - In fact, many still provide such kits including H-D... But most users have no idea how using those kits modify the otherwise excellent carb into a narrow condition good plus wide condition poor carb.
As the Sportsterpedia notes: Check the Main Emulsion Tube - The STOCK Keihin tube has 2x2Hi+4x3Lo Emulsion Holes - DJ uses only 2Lo Holes.
The OP's tube matches the Keihin design.
