0 Thread revival
Last Post: gusm2
Last Post: Jcolleyoh
Last Post: Billy1200
0 Bendix insulator block
Last Post: JonesL
Last Post: H.E.L.M
Last Post: simonster123
0 Black jugs matter
0 1968 xlch
Last Post: Hellbent_4
0 Intermittent electrical problem
Last Post: LLOYD883
14 2000 Front turn signal relocation kit INSTALL
Last Post: Akdawg
Last Post: Woody9225
0 THE Hockey Thread
0 Removing oil tank DIY?
0 Ignition advice
0 Speedo/Turns signals/Brake light dont work
Last Post: Joe_jeep
0 Why cafe a sportster?
Last Post: Merch131ho
0 show me your sporty next to an old or rural post office
0 Adaptive headlight issues
0 Post Your Seat Pics Here !!!
0 High idle code P0505
Last Post: dayypete
0 Range to Empty jumps and is on LR most of the time
Last Post: Blacklace
0 Easy Brackets on 93 Sporty
Calcustom's Avatar
Calcustom Calcustom is offline
Calcustom has a brilliant futureCalcustom has a brilliant futureCalcustom has a brilliant futureCalcustom has a brilliant futureCalcustom has a brilliant futureCalcustom has a brilliant futureCalcustom has a brilliant futureCalcustom has a brilliant futureCalcustom has a brilliant futureCalcustom has a brilliant futureCalcustom has a brilliant future
Default 04 brake upgrade question
In my quest for better braking I picked up a Speed Merchant caliper mounting bracket and a Tokico caliper.
I plan on rebuilding the caliper and storing it until a suitable 19" wheel turns up.
I know thaty typically brake fluid is used for the sleeves and pistons but since It wont go into service for who knows when I wanted to use a product that would hold up till the planets align.
My question is has anyone used Red Rubber Grease like the stuff from Castrol and is this the product I should be looking at?
Thanks
harley506d's Avatar
Sportster/Buell Model: 1200c
Rubber grease will be fine and then store somewhere warm and dry, but why not mount it now?
spitfirechopper's Avatar
spitfirechopper spitfirechopper is offline
Sportster/Buell Model: ironhead xlx
Sportster/Buell Year: 1983
Sportster/Buell Year #2: 2005
spitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud of
Thanks
Are you running this on a mag wheel or spoked? i didn't buy this because it says it wont clear a spoked wheel but the bike in your pic has a spoked wheel?
Calcustom's Avatar
I am looking for a 19" mag wheel. like this one.
This is a requirement for clearance issues with this adapter.
If I'm patient one will eventually turn up at a reasonable price.
I'm making some changes that had been suggested in an earlier post of a better caliper and a 19" wheel both of which made perfect sense.
I am also making some other changes at the same time.
Just having fun with it.
harley506d's Avatar
That looks a fantastic brake set up! I would love to have the same.
Have a look on sportsterpedia re wheels etc, there is everything you need to know. http://sportsterpedia.com/doku.php/t...k:evo:wheels01
My 13 spoke came off a Dyna, so plenty of choices out there.
You could even try offering a swop deal, you never know someone may be looking to go the other way.
shanneba shanneba is offline
For the caliper pistons HD recommends KS62F assembly grease.
For the caliper bolts and boots G40M BRAKE GREASE
Both are supplied to Harley from CHEMTREC®
I have been using ATE Plastilube Brake Lubricant when lubricating my brake components, pad pins, rubber boots etc. (I haven't rebuilt the calipers yet)
https://www.ate-na.com/products/ate-...ake-lubricant/
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Calcustom's Avatar
This is great information.
Thank you all!
Old 4 Days Ago
Sportster/Buell Year: '59
Other Motorcycle Model: 2006 XL1299R
PetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant futurePetesPonies has a brilliant future
I have dual Tokico calipers on my Roadster. I bought mounts from Kevfab . originally for factory mags. But I ended up going 16" wire spoke and they still fit.
Pete's Ponies Mustang RUSToration & Performance . . retired Auto Instructor
