0 2009 XB12R make over.
Last Post: salmanmr
0 Proper XLCH
Last Post: Magneto Sportster
0 Another Wrap Post
0 Top mount steering damper?
Last Post: salmanmr
0 What a birthday I've had
0 Need some guidance on installing a traxxion dynamics suspension on my front forks
0 Ignition swap (compatibility?)
0 Problems relocating coil
0 Ironhead carbs
0 "03 vs 04+ Cylinders & Heads: Different Carb Bracket?
Last Post: screndname
0 Gearing Help
Last Post: BigMek
0 baker 6 in 2000 883 conversion primary vent drips
Last Post: Randy_rots
0 Fixing Digital Gear Indicator
0 Top end failure
Last Post: Mission1
0 Info needed on mini sumps.
0 Graduated to Ironhead
0 Inherited Ironhead
0 yost power tube guy
0 FDR Drive pothole did this...if u can believe it
0 Looking for an xlch engine
Last Post: Medyo Bastos
0 Chinese S&S carbs
0 dieseling ? solenoid ? help
Last Post: keithnh
33.4mm, fork tubes, front end
Old 1st November 2018
Old Junk Old Junk is offline
Sportster/Buell Year: 1969
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1971
Other Motorcycle Model: XLCR Tribute
Other Motorcycle Year: 1980
Old Junk is an unknown quantity at this point
Default QLong-winded question: what length should my front fork tubes be?
Long time lurker, now with a big question. I'm putting together a '69 XLCH. Not exactly stock, there's a mix of reconditioned junk, nos, aftermarket, swap meet pickings, etc.
The nos frame and swingarm have been painted & assembled, the wheels are ready to be mounted, and I've got people much smarter than me (my local indie) trying to put the front end together so that this can be a roller. I bought a Frankenstein front end from ebay and I'm trying to get it back to stock, with the rubber boots/gators.
Here's the trouble: The fork tubes (22 3/4" long repops purchased from Fleabay) seem too long once assembled in the lowers; the fork gators are stretched out WAAAY too much to look normal.
My indie shop is great - they do lots of old Harley stuff, but mostly work on big twins. They have a stock, unmolested '69 XLCH for comparison. Side by side, seems like my re-assembled front end is about 4" too long compared to the stock '69 front end.
I don't have any photos. Sorry, I know that's stupid.
I've seen a few threads on 33.4mm tubes. I remember reading about TWO part numbers for two different fork tubes with DIFFERENT LENGTHS from this era. But of course I can't find that thread now...
Lowers seem to be correct. Tubes seem to be correct. Springs and guts seem to be correct.
Could it be that my fork tubes are too long at 22 3/4"?
Or does this front end need to be put under load somehow to fit together properly?
Or is there some other explanation of why the front end seems too long?
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
22 3/4 would be the correct length. are there any pipe spacers above the springs?https://www.bikernet.com/pages/Fork_...imensions.aspx
JonesL JonesL is offline
Sportster/Buell Model: XL
Sportster/Buell Year: 1971
With the bike fully assembled, the front end ought to settle quite a bit. Short of simulating the weight of engine/trans plus full gas tank and rider. not sure there's a way to tell for a roller chassis.
If your shop guys are sharp and are assembling with OEM or at least OEM dimensioned parts, then you should at least be in the ball park.
My book shows the lowers as one choice, only difference is left or right side.
The uppers are 45953-68 SLIDER TUBE (2) (high road clearance)(standard) 68-70 XLH, XLCH.
or 45955-68 SLIDER TUBE (2) (low road clearance)(optional) 68-70 XLH.
Hope this helps.
"If a camel flies, no one will laugh if it doesn't get very far".
In Damper Tube forks, the length of the upper slider & the length of the damper tube determine the maximum possible length from the top of the slider to the axle...
Since the damper tube slides down into the upper slider and mounts to the BOTTOM inside of the lower slider, this sets the maximum length. The only other factor is if you have top out springs between the damper tube HEAD and the BOTTOM of the lower slider... but this will shorten the overall length of the slider/damper rather than extend it...
In some lowering kits, extra top out springs are used to reduce the distance the damper extends below the bottom of the upper slider - but that also reduces the overall fork suspension travel...
IXL _______ >>>> My Motorcyle Chronicles Are Here<<<<
Check Out The Sportsterpedia
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
Buy ones that fit. About $6 at auto parts stores.
Or here: https://www.ebay.com/sch/i.html?_fro...cat=0&_odkw=sc
Default Thanks
Wow! Thanks for coming through, everyone. I'll share this info with my indie and see if it helps.
The very best choice for boots for Sportster 35mm forks is the Honda GB500 part number 51611-KN8-003. They actually fit perfectly. Most others will not fit the 35mm dimension. Get them at your local Honda dealership.Any motorcycle shop should also be able to order them.
you can get the correct ones from an H-D dealership IMG_0038 (1) by Bruce Stoudt, on Flickr p/n 46001-54 it's on the package but not easy to read. these are for the early 33.4 mm forks.1969 included.
Old 2nd November 2018
Ooops, I saw 1979 in the post header, did not notice the question is about 1969.
Old 3rd November 2018
Magneto Sportster's Avatar
Magneto Sportster Magneto Sportster is online now
Sportster/Buell Year #2: 1960
Other Motorcycle Model: XLCH
Other Motorcycle Year: 1959
Magneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond reputeMagneto Sportster has a reputation beyond repute
The forks will sag when the engine is in the frame and everything is on the ground. That's probably why the complete bike looks different
"Ride 'em, don't hide 'em!"
