0 Rubbermount Poll
0 Oil Level: Hot vs Cold
0 Hi from the UK
0 Front brake shorting?
Last Post: Hughieboy
Last Post: Vegas_Charger_Fan
0 Question of the month?!
Last Post: The Crusher
0 Keith Black Conversion
Last Post: 1HD4CJM1X4K
0 "S" model specific Q&A
Last Post: Edster
Last Post: paulc
Last Post: paulc
0 Keith Black 10:1
Last Post: Boudwood
Last Post: Sportycus
0 09 Buell XB12 crank
Last Post: Boudwood
Last Post: mrmom9r
0 Magnaflow F-Bomb on a Rigid?
Last Post: JoelDeb89
0 What color are your pipes?
Last Post: jordan1200
0 nine T racer
Last Post: Mad Max
If you put in extra discs in the clutch the stack height may be too much to properly release.
You should have 8 steels and 8 frictions, start with a friction against the stud plate with spacers, end with a steel, then the thick 9th friction (one sided) disc last, under the retaining ring then the springs and release disc. DO NOT OVER TIGHTEN the nuts, I always use new nylocks.
I prefer the dual coil springs (stock) as they are wound opposite directions to counteract the rotation caused by compressing them.
Belleville springs might just work, might have to stack a couple to get enough motion and make an insert to space them and center them on the hub.
Serious Blac's Avatar
Serious Blac Serious Blac is offline
Sportster/Buell Year: 1982
Other Motorcycle Model: Oh yeah!
Serious Blac has much to be proud ofSerious Blac has much to be proud ofSerious Blac has much to be proud ofSerious Blac has much to be proud ofSerious Blac has much to be proud ofSerious Blac has much to be proud ofSerious Blac has much to be proud ofSerious Blac has much to be proud ofSerious Blac has much to be proud ofSerious Blac has much to be proud ofSerious Blac has much to be proud of
"Belleville springs might just work, might have to stack a couple to get enough motion and make an insert to space them and center them on the hub". Once I get the loads measured I'll have to go through the catalogues and see what is available and then do some maths to get some with the right static loading. If I'm lucky it may be possible to get a light clutch pull too which would be nice. I have my own lathe so spacers shouldn't be a problem. The Evo uses a type of belleville washer and I was wondering if this could be adapted but looks to be a bit big.
The Devil is in the detail.
mikethebike61's Avatar
Why the hell would you replace a single or dual spring with SIX smaller ones? Seems like more trouble to me..
8ball's Avatar
8ball 8ball is offline
Sportster/Buell Year: 1973
Sportster/Buell Model #2: xlch stroker
8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of
not that it makes it equal by any means but you ever ride a dry clutch ironhead? its like having sex for the first time...
6 springs even the load WAY more that dual stock or single am.
the amf wet was cheaper to make thats why it was grafted. you see any other bikes with a setup like that? just the stud plate and retainer ring alone is a "how can we make this work opposite of normal" ordeal.
ill give its surely cheaper to manufacture but throw a few more cubic inches at it and ALL its downfalls come out.
get it tuned well and even worse.
my 3rd gear is literally cruse only. maybe 1/4 throttle before it lets loose. thats with the xr hub/drum mods.
to put it mildly ironhead wet clutches were a major downfall to these bikes.
"ya...i saw a guy do this once... " -DR DICK
Do you know what a belleville washer is?
https://en.wikipedia.org/wiki/Belleville_washer
when I was at A.M.I they referred to that clutch as the reverse action clutch.
You mean like the 4 on my 560 SEC crankshaft bolt?
200+ hp BMW R1000RR, Yamaha R-1. GS- 1000, Kawasaki 1000 and every other (save for Ducati and they dumped the dry for wet in most street bikes)
go-to-hell-fast street bikes run wet clutches....I've had both and on the street I will take wet over dry anyday
