0 Rubbermount Poll
0 Oil Level: Hot vs Cold
0 Hi from the UK
0 Front brake shorting?
Last Post: Hughieboy
Last Post: Vegas_Charger_Fan
0 Question of the month?!
Last Post: The Crusher
0 Keith Black Conversion
Last Post: 1HD4CJM1X4K
0 "S" model specific Q&A
Last Post: Edster
Last Post: paulc
Last Post: paulc
0 Keith Black 10:1
Last Post: Boudwood
Last Post: Sportycus
0 09 Buell XB12 crank
Last Post: Boudwood
Last Post: mrmom9r
0 Magnaflow F-Bomb on a Rigid?
Last Post: JoelDeb89
0 What color are your pipes?
Last Post: jordan1200
0 nine T racer
Last Post: Mad Max
View Poll Results: When you park your bike, do you leave it in gear?
Leave it in neutral 171 33.08%
Leave it in gear 261 50.48%
It varies (please comment) 85 16.44%
Voters: 517. You may not vote on this poll
  #351
Nibelungen's Avatar
i had the habit since kid to park in neutral my bike... kickstarter bikes taught me that habit...
once in a while, when forced to park uphill... obviously i parked her in first gear
in that cases i had to remember that... when fired up my bike later...
nowadays with the clutch switch, your bike does not roar into life if you have the gear engaged and have not pulled the clutch... (overtime i had to shim that switch though... cause it was not properly engaged when the clutch was completely pulled)...
Bone's Avatar
Bone Bone is online now
Sportster/Buell Model: 1200Lr
Sportster/Buell Year #2: 2016
Originally Posted by Jason's Sporty View Post
In 1st gear. Never trust the Dime size contact and spring of the kickstand to keep it from moving.
Hmm, wonder what's bigger the contact area of the kickstand and bracket at the lock point or the surface area of the engaged teeth on the countershaft/mainshaft?!?
Bone's Avatar
Same here........ leave it in 1st. Just a little bump or somebody leaning on it could send it rolling off into traffic or falling on somebody.
SLW210's Avatar
SLW210 SLW210 is offline
SLW210 is a splendid one to beholdSLW210 is a splendid one to beholdSLW210 is a splendid one to beholdSLW210 is a splendid one to beholdSLW210 is a splendid one to beholdSLW210 is a splendid one to beholdSLW210 is a splendid one to beholdSLW210 is a splendid one to beholdSLW210 is a splendid one to beholdSLW210 is a splendid one to beholdSLW210 is a splendid one to behold
I usually leave mine in gear, just because it's in gear when I stop, if I am running the bike on the stand in neutral, I do not bother putting it in gear, either. It doesn't really matter, the bike can still roll in gear, not sure that's a good reason to put it in gear for parking. If you really want to stop rolling when parked, you need a brake lock or disk lock. AFAIK the Harley locking side stand works as well as the brake locks.
