0 Occasional carb spit back, am I missing something?
Last Post: ezmerf
Last Post: JaKaL
0 Grounded
0 Thursday 18th July 2019: Lympstone
0 Oil Filter Thread Size/Pitch?
Last Post: Rollbar
0 rattles like a can of bolts
Last Post: spamer80
0 2020 Sportster?
Last Post: Desertfox
0 Power Loss At Sustained High RPMs
Last Post: Bigshankhank
Last Post: a-sad-anorak
7 I met a living legend.
0 looking to swap mids for forwards
0 What jets do you use?
Last Post: 83XLX
0 For Sale: SE Race Ignition Tuner 32124-04B/Stock ICM
0 Cold Start. Then stall
merc, schvamf (47), MikeLightnin, o2man98 (39), Toadz (31), WingNut15B (31)
Old 5 Days Ago
smm1200 smm1200 is offline
Sportster/Buell Model: 1200xl
smm1200 is an unknown quantity at this point
Default EFI hose clamps
I am having problems with a NOS sportster, 08 with 2700 miles that had its pump replaced last year. Gauge on the way to check pressure. The pump has let me know with loud squeal/whine that it is not happy. Trying to get parts in order in advance. Any one know what size the small hose clamps on the corrugated hose on the pump. I have 12.8, but cannot tell whether they might be 12.3 or 13.3....hmmm. The HD part does not help since no one describes size. thanks in advance.
Old 5 Days Ago
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
Are you sure its the oil pump making the noise? What is the history of the bike? Oil pump replaced with only 2700 miles? Was oil circulating? Are the oil lines kinked or not going where they should? Might have other engine issues if oil wasn't circulating.
04/07 1275 BFH heads .590 cams S&S 1.725 rockers S&S premium lifters BDL+15% clutch TC88A HSR-45 S&S 3" ac LSR 2-1
Old 5 Days Ago
seajay....thanks for reply....but this is EFI, fuel, pump hoses. Was not talking oil pump. Sorry for any confusion.
Old 5 Days Ago
seajay's Avatar
Yeah, I got you. I'm a carb guy.
Old 5 Days Ago
b0fh's Avatar
b0fh b0fh is offline
Sportster/Buell Model: XL883R
Sportster/Buell Year #2: 2017
mine does a horrible noise on turn-on whenever i let it sit for too long like a week or more. sounds like a cat dying... also a 2008 and does this since new, pump still pumping strong
Old 5 Days Ago
Air-Cooled Forever
Sounds like the pump is dry, does it somehow lose it's prime, especially when setting for a while?
Old 5 Days Ago
b0fh's Avatar
no idea. this particular bike (its an 883) never failed to start on 1st try its whole life, even when sitting for more than a month due to work travel and whatnot.
just makes the dying cat sound for a minute or so.
Old 5 Days Ago
Sportster/Buell Model: xl1250
Hi,
So you had the fuel pump replaced last year? You now have 2700 miles and you are having squeal type noises when first priming the fuel pump. Are there any other problems with fuel this pump beside the noise? ( i know you are waiting on a pressure gauge to test it) . What was wrong with the first fuel pump?
I have a 2008 and mine has always made squeal, almost grating sound noises when turned on. It is worse when it has been sitting for a while at "first start" after sitting for long periods ( days, weeks etc) Always works and i have not noticed the bike suffer from incorrect fuel pressure. I think i remember reading that it not unusual to have noises from primming of the pump prior to starting. Please keep us informed. Ride safe.
Old 4 Days Ago
Air-Cooled Forever
You can probably dismiss this as pure Bullshit, but if I had an EFI bike and the pump made a constant start-up squeal I'd be tempted to run a small amount of 2-cycle oil, mixed with the gas, to help lubricate the internal parts of the pump. Maybe it would help, maybe not. It shouldn't damage the pump.
Old 4 Days Ago
thanks for all discussion. ....the press gauge today.....runs near 60psi....so pump working. Not sure about flow rate.....not easy to just turn on pump and let it flow w/o another adapter.....the fittings have internal checks. But, revved up and no press loss.....soooo. Will now pull tank and pump assy for next steps. At this point I will replace some parts. Called dealer on parts....said they would call back...nonesuch. I still would like to know about size on the single ear clamps...may have to just go to harley to see if they have parts. Intend now to look at screen and filter, and probably replace pump as well due to noise....but I hear your points above on noise and been OK, I may change my mind on the pump for now since pressure ok. Will follow up with more findings. Now worried about injectors....maybe other problems like electrical since it just shuts down under full throttle over last several runs. But, will just follow the dots for now. thanks again.
