Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Styles > Sport-Glide / Sportster Motorcycle Touring
0 S&S MGAL carb
Last Post: fafcpa
Last Post: Eddieblz
0 Coil OK but no Spark??
Last Post: cdnsportster
Last Post: Eddieblz
0 Power cones
Last Post: JonesL
0 Arlen Ness Fairing
Last Post: hondo
0 can you tell me why?
0 Wheel fitment
5 Tire Pressure?
Last Post: Joe_jeep
6 English newbie
0 Fitting mini apes
Last Post: ivanford
0 .551 Cams in an EFI 1200
0 Forum member mug shots
0 Convert to wide glide front end
Last Post: motorfish
Last Post: Joe_jeep
0 ultima electronic ignition
0 will these fit my 2006 xl 1200c
Last Post: mwXL 2006
0 Noisy
0 93 Sporty Key replacement
0 Wheels
Last Post: NoRemorse
0 Wont shift from 1st to 2nd
Old 9th February 2012
Diveanx's Avatar
Diveanx Diveanx is offline
Sportster/Buell Model: 883 100 Anni Edition
Diveanx has a spectacular aura aboutDiveanx has a spectacular aura aboutDiveanx has a spectacular aura aboutDiveanx has a spectacular aura aboutDiveanx has a spectacular aura aboutDiveanx has a spectacular aura aboutDiveanx has a spectacular aura aboutDiveanx has a spectacular aura aboutDiveanx has a spectacular aura aboutDiveanx has a spectacular aura aboutDiveanx has a spectacular aura about
I need an opinion I mounted the rear marker lights so I need an opinion. Should I put them on the outside or the inside.
What do you guys think look better? Keep in mind that there will be a wheel and fender between them.
Please excuse the finger prints LOL
Brad Brad is offline
Sportster/Buell Year: None
I like the inboard look.
snowman's Avatar
snowman snowman is offline
Why would anyone turn a perfectly good sporty into a bagger:
--Russ--
U.S. Army Veteran
***RIP***
--Mr. JIMI
--JOHNNY G
--BryanEOD
d_eggman2's Avatar
d_eggman2 d_eggman2 is offline
Other Motorcycle Model: 96 Honda 300 4TRX
d_eggman2 is a splendid one to beholdd_eggman2 is a splendid one to beholdd_eggman2 is a splendid one to beholdd_eggman2 is a splendid one to beholdd_eggman2 is a splendid one to beholdd_eggman2 is a splendid one to beholdd_eggman2 is a splendid one to beholdd_eggman2 is a splendid one to beholdd_eggman2 is a splendid one to beholdd_eggman2 is a splendid one to beholdd_eggman2 is a splendid one to behold
I vote for outside.
Forgive your enemies, but never forget their names.
John F. Kennedy
When I was old enough to ride a motorcycle and got my license, I bought a '69 Sportster.
Chuck Zito
A man who carries a cat by the tail learns something he can learn in no other way.
Mark Twain
Diveanx's Avatar
This coming from the man that has the best looking one out there LOL I love the look of your black one :-)
Old 10th February 2012
Diveanx's Avatar
Well have been told my bike is done and I can pick it up tomorrow so I hope that I can start my project this weekend
Old 11th February 2012
Diveanx's Avatar
Well the bike made it home last night and I was told I need to clean out my tank that it looks like it has sand in it. Not sure how that happened because I buy gas at the same place every day accept one day so not sure.
I couldnt wait to start my project so parts are coming off. I started with the right side and removed the seat amd turn signal. Now for people that have never taken your turn signal off, it can be kind of a pain. there is a long bolt )I will provide pictures when I am done) that is two sided. It has a short section that bolts to the frame and the long section that goes through the chrome extension to the light itself so most of the time when you take it off (if it has been installed correctly with loctite) the bolt will come out of the light end before it comes off the frame and then you can hold the bolt and finish taking it off. The other thing is you have to remove the taillight lense to unhook the wire to the turn signal. The wire is pretty tight so I suggest unplugging it first.
Next I had to remove the shock bolt because on my bike there is a chrome cover that goes over the fender strut. You would think that you wouldnt have to remove this but the hole that the wife for the turn signal is not large enough for the plug to come through so I had to remove the whole thing. Now I will have two options if I want to reinstall the chrome cover, I can cut the wire (since in my situation I am not reinstalling the stock turn signals) or I can take the wires out of the connector. Not sure what I am going to do yet.
After removing these items I was ready to mock up the mouting system which contains to mount itself and a chrome bar that in my opinion is there to add a place to add the stock turn signals if you have room. I am going to look at it both way to see how it looks.
Well that is all I have done so far. Once I am done I am going to add the pictures with the step by step so everyone can see that anyone can do things like this with just a few tools. Until the next version
FWIW - when I removed my TS, I left the chrome strut covers off.
Diveanx's Avatar
Well I woke up all excited to work on the bike this morning. I went in the garage and got my tools all together and cut the tunes on and started away.
I removed the turn signals and in my situation I decided to keep the chrome strut covers on the bike because the chrome bar that comes with the kit covers the holes where the turn signals were located.
I looked at the mounts and something just didnt seem right to me but I decided to continue. I installed the right side first and it looked weird. I didn't worry about it at first. I decided to work on the frame that goes on the tag that has the turn signals on it.
I drilled a hole in the bracket and the fender to run the wires through under the fender and into where the turn signals plug into the rear light.
I tried wiring the lights and they did not seem to work right. I have no clue why. Just one of thise things that I will figure out later.
My major problem at this point getting back to my earlier issue is that the mounts do not go straight down. They angle out at the bottom and that makes the bags look stupid so right now I am at a stand still until I get information from the company that made the mount as to why it does not work correctly.
So long story short I am not happy at this point
Old 17th February 2012
Diveanx's Avatar
Okay just a little update. I have decided to take a different route with the rear saddle bag lights as well as the turn signals.
Today I purchased the Harley lay down license plate bracket and turn signal relocation kit (pn 60215-06) Not the description states that it is for a 2004 Sportster forward but it uses the same 3 bolt pattern that most Harleys use so it bolted right up. Now the one thing I did have to do was drill a hole in the fender for the wires to go through.
The kit comes with new terminals because you have to take off the connectors but unless you have a 150.00 crimper and lots of patients you will never get that to work. What I did was cut the wires about 3 in backs and then just soldiered them back together and used skrink tube over it and you cannot tell it from a factory install. I will show the install once I get pictures tomorrow. The system is a tab bit expensive but well worth it for the type of fit and the look.
I have now figured out a way to mount my bags without modifying the brackets. I found a website that sells various vibration mounts that have studs on each end. Its a great site and if anyone needs the site let me know. but I found some mounts that will hold about 76 pounds each so will be more than sufficent and the mounts are like an inch thick and that should straighten the back up on the mount and make it look good.
I will post more when I get the mounts and add them to the bags. Thanks for hanging in there with the post
