0 H4 LED Conversion - write up with photos
0 weld on hardtail
0 Down on oil
0 CV Carb hesitation
0 Mounting seat
Last Post: guidowisozk
0 TC88A EX lower MAP settings
0 Magneto insulating block removal
0 magneto twin plug heads
0 Cosmo's ECM Relocation Mod
0 i want a narrow/standard mustang vintage
5 Wet Dream, Ever Have One?
Last Post: Joe_jeep
0 Round Air Cleaner Poll
Last Post: Joe_jeep
0 Clutch Q
Last Post: wrkdWS6
0 Chinese S&S carbs
Last Post: Hornsmith
Last Post: BWP 5p
0 Rear wheel alignment
Old 4th July 2015
DELETED ACCOUNT - MY CHOICE DELETED ACCOUNT - MY CHOICE is offline
No Posts
DELETED ACCOUNT - MY CHOICE is an unknown quantity at this point
I don't know about the jetting. Would the w cams be making it go flat at the higher rpms? The hammer builds with 560 cams normally pull to 7800rpms.
Old 4th July 2015
rocketmangb's Avatar
Thats not really the AFR from what I can read
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 6th July 2015
cdirk cdirk is offline
cdirk has a spectacular aura aboutcdirk has a spectacular aura aboutcdirk has a spectacular aura aboutcdirk has a spectacular aura aboutcdirk has a spectacular aura aboutcdirk has a spectacular aura aboutcdirk has a spectacular aura aboutcdirk has a spectacular aura aboutcdirk has a spectacular aura aboutcdirk has a spectacular aura about
I just did the compression test. Both Front and rear were around 225. Throttle open position, Float Pushed up.
Is this too high? Or is this reasonable....
Old 6th July 2015
Thats pretty damn high.
Lets see that Daytona Map you have
Old 6th July 2015
I will need to download it and send it. Or ask him to email me a copy of it. He showed it to me before I left. I will send along when I get it if not tomorrow Tuesday night when I get home.
Old 6th July 2015
Whos map was it ?
The dyno shop ?
Old 6th July 2015
Rico's was what he started with. Then Dyno shop modified the map.
Old 6th July 2015
Even more reason to look at it.
Rico has written many great maps and most Dyno guys have no clue.
Old 6th July 2015
I bet...the before and after dyno sheets did show a decent improvement. don't have them in front of me but it was something like 6HP and about the same in TQ increase over Rico's map across most of the range from 3000 to 6000 RPM's.
Old 6th July 2015
Frankly the TQ numbers look good but over a very narrow range
The HP not so good and make no sense to me.
It really should be up in the 80's and I sure dont see a 200 main jet being needed
