0 S&S MGAL carb
Last Post: fafcpa
Last Post: Eddieblz
0 Coil OK but no Spark??
Last Post: cdnsportster
Last Post: Eddieblz
0 Power cones
Last Post: JonesL
0 Arlen Ness Fairing
Last Post: hondo
0 can you tell me why?
0 Wheel fitment
5 Tire Pressure?
Last Post: Joe_jeep
6 English newbie
0 Fitting mini apes
Last Post: ivanford
0 .551 Cams in an EFI 1200
0 Forum member mug shots
0 Convert to wide glide front end
Last Post: motorfish
Last Post: Joe_jeep
0 ultima electronic ignition
0 will these fit my 2006 xl 1200c
Last Post: mwXL 2006
0 Noisy
0 93 Sporty Key replacement
0 Wheels
Last Post: NoRemorse
0 Wont shift from 1st to 2nd
  #31
Old 25th May 2016
rocketmangb's Avatar
I really needed to keep notes !
I need to check my main,seems small at 165
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 25th May 2016
wedge's Avatar
wedge wedge is offline
Yes, you had a 167.5 to begin with, and we misread that and thought it was a 162.5, and that set us off in the wrong direction for a while. We finally ended up at 165. (one down from the 167.5 like we tried to do first).
I am a bit curious about that too, it seems small, and mine took the 170. But then yours is a HSR45, and mine is HSR42, so it's going to be somewhat different for sure.
Your plugs looked too lean too, so... How long were the plugs in that you rode there with? I would have expected more color even just from Sbdo.
Old 25th May 2016
It looked lean all day
Remember I had to change plugs when the pistons closed up the gaps ?
Old 25th May 2016
wedge's Avatar
I know that, but the question was, "how long were those first plugs in the bike" (the ones that were in when you rode over with the gaps hammered flat)?
I'm thinking that especially with the gaps all closed up, they should have been more on the black side than dead lean looking.
