0 Does 20W60 reduce cam gear noise?
0 Hagerty Insurance
Last Post: Pigskinner
0 TC88A EX lower MAP settings
0 Poll: Saddlebag Supports
0 magneto twin plug heads
Last Post: marioserafica
0 Fun or money?
Last Post: bill smith
5 Wet Dream, Ever Have One?
0 Down on oil
Last Post: Billy1200
0 1968 xlch
0 blonde, brunette, red?
0 Hamburger drum brake clunk noise
Last Post: nickfracture
11 How much did you spend on accessories in the first month?
0 I'm here to introduce Gristle.
Last Post: apotheon
Last Post: Randy_rots
Last Post: apotheon
0 Wish I had a beach with a ocean
Last Post: Akdawg
10 big bore question
0 Transmission figment
0 Smoke and top end job
win307 (66), JrzyDave (59), WeirdNJ (59), Pigskinner (46), jeepsoldier (44), Virgdog (34), bernardderek, John Titor (22)
Old 3rd April 2019
Phappus Phappus is offline
Sportster/Buell Model: Custom Bobber
Phappus is an unknown quantity at this point
Default Superlow wheels
I’m doing a sporty based chop/build street tracker themed bike. I really like the superlow wheels.
I was wandering if anyone had the hub dimensions, width and wheel offset?
Old 3rd April 2019
For 2012-later, according to the Sportsterpedia data, the two bearings and the internal hub spacer = 163mm (6.417").
I'm assuming that would be flush with the hub faces ---
How accurate of a measurement do you need?
http://sportsterpedia.com/doku.php/t..._axle_bearings
http://sportsterpedia.com/doku.php/t...nt_hub_spacers
For 2012 later models -
Based on the SP data, the spacers are:
Center ----- 5.236 (133mm)
Rt Bearing - 0.591 (15mm)
Lt Bearing - 0.591 (15mm)
--- Total -- 6.417 (163mm)
We don't have any measurements on the outside spacers...
Check The Sportsterpedia - The Best Kept Secret on the XLForum!
Old 3rd April 2019
Thanks! I should of stated what I know. I was tracking that. When I looked at some I noticed the rotor side bearing is inset about 1/4 in eyeballed and the pulley side about flush. The other thing I noticed was the hub is offset from the wheel centerline toward the rotor. I was looking for the measurements to see feasibility with swingarm build and alignment with desired gearing
