Last Post: Eddieblz
0 Coil OK but no Spark??
Last Post: cdnsportster
0 S&S MGAL carb
Last Post: thefrenchowl
Last Post: Eddieblz
0 Power cones
Last Post: JonesL
0 Arlen Ness Fairing
Last Post: hondo
0 can you tell me why?
0 Wheel fitment
5 Tire Pressure?
Last Post: Joe_jeep
6 English newbie
0 Fitting mini apes
Last Post: ivanford
0 .551 Cams in an EFI 1200
0 Forum member mug shots
0 Convert to wide glide front end
Last Post: motorfish
Last Post: Joe_jeep
0 ultima electronic ignition
0 will these fit my 2006 xl 1200c
Last Post: mwXL 2006
0 Noisy
0 93 Sporty Key replacement
0 Wheels
Last Post: NoRemorse
0 Wont shift from 1st to 2nd
  #131
Old 1st October 2018
Nibelungen's Avatar
Sportster/Buell Model: xl883n Iron (2019 engine)
Originally Posted by r4fthrs View Post
Barnett Kevlar
yes used the original spring
Funny thing, was told by an old mechanic that used to work on some of the HD factory racers and he said they all had Barnett clutches. Not sure if true, but he seemed like a stand up guy.
I have heard good things about the Alto and a few others, but I was familiar with the Barnett from my racing days
IMO it can be true...
on circuit could be an advantage have coil springs actuated clutch... instead of diapghram spring ones...
and if i'm not wrong Barnet have some models like that...
on the lion's corpse celebrate the dogs... still the dogs are dogs and the lion a lion...
Old 2nd October 2018
Graywolf Graywolf is offline
Yes, they do. Barnett Scorpion clutch has coil springs instead of diaphragm. I have one. Works really smooth and easy to keep in adjustment.
Graywolf
Old 13th July 2019
Gibson90kb Gibson90kb is offline
Sportster/Buell Model: Xl883l Conv
Sportster/Buell Year: 06
Other Motorcycle Model: Vulcan 1500
Other Motorcycle Year: 2000
Gibson90kb is an unknown quantity at this point
1. Year of bike 2006
2. Model 883>1200? Unsure of which exact swap.
3. Miles on clutches? ~30,000 definitely started going a few thousand before I replaced.
4. Fluid used when slipping of clutch began? Revtech chaincase oil. Sportster specific.
5. How many miles on that same fluid? I change my fluids almost monthly. Usually every couple thousand.
6. Did you perform routine adjustments per the service/owners manual? No only as needed.
7. Your riding style: Raped ape aggressive
