0 How packed is your garage?
Last Post: unleashed
0 The Revolution's Rowdy Ancestor?
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
0 Generator removal
0 '81 Gasket/Rebuild Questions
0 Struggling with year??
Last Post: Calcustom
0 oil line routing 79 ironhead
Last Post: bobandy
0 Forum member mug shots
0 THE Hockey Thread
0 4 Speed Stator Replace
Last Post: connorneil13
0 Polished rotor/brake pad compatability
Last Post: Firehawk
Last Post: Firehawk
0 Dynatek Ignition questions
0 compression low?
Last Post: 93trident
0 Hello from the uk I just got my first Harley!
Last Post: Sugarsinner
5 1969 XLCH exhaust question
Last Post: Coz
0 I'm back...
Last Post: screndname
0 Random video thread.
5 RSD LED Indicator
Last Post: mk87ita
DAKSY (68), dwagar (68), DaveDuff (59), chaserband (57), bigcraig74 (46)
throttle cable adjustment
Old 21st October 2008
chronisj chronisj is offline
Sportster/Buell Model: 1200 Sporty
chronisj is an unknown quantity at this point
That helped ALOT!!! make so much sense now.
Oli1200's Avatar
Oli1200 Oli1200 is offline
Oli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of lightOli1200 is a glorious beacon of light
Seriously, for something so simple there seems to be a 100 different ways and bits of advice out there on how to adjust thrοttle cables. Chris Hajer, that was good. Basically what the manual dictates.
I run the stock carb but have 8+ stock extended Barnett thrοttle cables. With my pull cable slacked off completely it still reaches the cam stop.
My way of doing it quickly has been to turn the bars fully to the right, slack the adjusters off completely, then tighten both adjusters with equal turns until there's only a little bit of slop in the thrοttle grip.
Old 8th December 2009
ultraeconomike's Avatar
ultraeconomike ultraeconomike is offline
Sportster/Buell Model: 2006 xl1200r
ultraeconomike is on a distinguished roadultraeconomike is on a distinguished road
I ride a 2006 Ѕportster xl1200r
I found my way over here via Screw Loose Dan's drag bar install thread. I have one question re: the thrοttle adjustment although it could apply to some other threads like the air box mod deal, anyway here goes: Are these instructions good for fuel injection as well as carbourated bikes?
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Why do you care? You have an '06.
Good question BTW.
Folkie
South East England Riders
I'm planning to put drag bars on my bike and Screw Loose Dan's thread said you have to adjust the throttle. The link here is for a carbourated bike and I wonder if the instructions will work for a fuel injected bike.
Folkie's Avatar
Brass Nut
But if you have an '06, you don't have a fuel injected bike. Or do you have an '07 model year bike, but made in '06? In which case, it's an '07.
This is embarasing I just checked the reg and it does say 2007!...I bought it 1/5/07 so I assumed since it was built in 06 it would have been an 06 model but I see now that production runs one year in advance of the model year. I guess you learn something new every day....
Folkie's Avatar
Brass Nut
Yeah, the '07 bikes came out in Autumn (Fall) '06. Some clever person can probably tell us what month that happens.
Uhm....but about my question concerning fuel injection vs. Carbs?
Folkie's Avatar
Brass Nut
I'm sure the principle is exactly the same. Can someone with an EFI bike chime in and tell us if there are any detail differences that Mike needs to be aware of?
