Last Post: spuggy
0 H4 LED Conversion - write up with photos
0 Help identifying brakes
Last Post: bobandy
Last Post: SCarty
0 weld on hardtail
0 Down on oil
0 CV Carb hesitation
0 Mounting seat
Last Post: guidowisozk
0 TC88A EX lower MAP settings
0 Magneto insulating block removal
0 magneto twin plug heads
0 Cosmo's ECM Relocation Mod
0 i want a narrow/standard mustang vintage
5 Wet Dream, Ever Have One?
Last Post: Joe_jeep
0 Round Air Cleaner Poll
Last Post: Joe_jeep
0 Clutch Q
Last Post: wrkdWS6
0 Chinese S&S carbs
Last Post: Hornsmith
Last Post: BWP 5p
0 Rear wheel alignment
Old 9th September 2012
A 4 liter V8 eater's Avatar
Sportster/Buell Year #2: 1999
I am going to try to round up a couple more dynos fore this thread that are scattered all over the forum and the web. Dynos along with a list of mods are an important reference.
I also recently reference the dyno below in my 88" flat tracker thread, This dyno belongs to NitroSportster:
Originally Posted by nitrosportster View Post
Here is the dyno sheet on my 87" sporty it made 131 h.p. and 110 lb torque yesterday. It makes 100lb of torque at 3800 rpm. The motor was built by Terry Reed. This motor has buell firestorm heads ported by terry that were built 4 years ago back when it was 74 cubic inches which i think makes these numbers pretty impressive.This is a street legal bike that i ride on the street and which i won the F.L.A.S.H race in iowa on. I plan on racing it in F.L.A.S.H class in AMDRAGS.
Mods:
87"
Redshift cams 643 or larger
Mikuni 48
Force Pipe
Terry Reed Prepped T-Storm Heads
Originally Posted by Mikel_NY View Post
hello all, I have my final tune on an 88" torque kit with a D&D 2 into 1 exhaust.
Attachment 9079
Once we installed a special needle jet ( midrange brass jet) the tuning went quick. I had Cycle Shacks with stock head pipes and gained over 22 tq (thru-3600), over 10 tq (thru 4400) and equaled thru 6000 then started gaining to +4 at 6500 !!! awsome torque increase.
The HP was +5 @3000, +12 @3600, +10 @4200, leveling to no gain at 6000 then gaining 4 @ 6200, to +9 at 6500.
This bike now makes over 80 tq from 2400 rpm to 6200 rpm (over 90 tq 3700-5000 rpm)
The peak number are 94.43 hp and 90.44 tq with the D&D 2-1 pipe
Originally Posted by isiahstites View Post
Well after almost a year of when I first built the motor I took it to the dyno with the intention of getting good power out of the motor. I have sat on tuning the motor for more power for quite awhile while I was making passes on the chassis and making sure everything was good there first.
Last night we were tuning the carb only, I have not touched the timing since I first set it last year. I will mess with the timing on the dyno prior to going to Bonneville this year. The 82 c.i. 1350cc 98' Buell motor I built made 128 hp and 101 ft tq!! I was really excited that the A/F is set-up correctly now and the bike made the power it did. We were going to make one more pass and felt it was going to make 1-2 horse more, but I broke my dam cast POS shifter shaft that slides onto the pawl. At any rate I think the bike will see a 130+ dyno pass in the future with some more fine tuning of the carb and playing with the timing.
I titled the thread the way I did because Dan promised me along time ago that my motor would make this kind of hp and it did! So a big thanks goes out to Dan for all of his help, all of the time! Thanks Dan!
I also wanted to thank Aaron (ASWracing)as well as he has offered quite a bit of very valuable info to keep me going in the right direction. Thanks Aaron.
Scott
Originally Posted by 88sporty View Post
I did a dyno run at NW HD bike show dyno shoot out. I won for sportster , 93.5 hp and 90.4 torque.
There is a big dip at 5500 - 6000 rpm, (needle clip position?)
The engine is Nallin 88 ci kit, stage 2 XB heads, N8 cams, HSR42, single fire, Daytona twin tech ign set on 3rd race slope. Hurricane AC.
The carb is baselined with 175 main, 97 needle clip in the middle, and 25 pilot.
The ignition is just static timed per book, I have NOT done any tuning of it yet.
So my questions would be, (I know dyno tuning is best, but I really dont have the $ right now) would turning the ignition CCW a tad help? would the dip be the clip position? which way, move it up or down?
Also, they do not give you the AF ration on the readout.
Thanks
ETA (the gaps are cable issues with the dyno)
This motor has been under construction in the shop recently, got it done yesterday and on the dyno today.
I'm not at liberty to say a whole lot about it. It's 82ci, we did the whole motor, ported the heads, designed and built the exhaust. We were hoping for 140hp and I still think we'll get there. The customer was up against a time limit and we left a little on the table just out of time constraints. But it'll be back in the shop multiple times over the coming year.
Last year it had less than this by a decent amount, and he ran a best of 10.12 @134mph. I want to see him run a 9 this year. No wheelie bars, no air shifter.
Originally Posted by Dana View Post
Have rebuilt 'MARINE1', hopefully for the last time. I'm posting the dyno sheet. Runs the strongest yet so maybe I'm through rebuilding and can get back to racing and riding.
DanaAttachment 9487
Old 21st September 2012
Old 30th December 2012
outside the box racing
Sportster/Buell Year: 99
Sportster/Buell Year #2: 2000
Other Motorcycle Year: 1991
82" turbo mutt engine, pump gas, 15psi
140hp/128tq
shooting for 160+
TGB #8
Old 6th February 2013
Jet 84" from their site:
84 cu" Buell ®
1999 S1 Lightning completely balanced and blueprinted
113 HP, 105 FT LBS Torque (SAE corrected)
1996 S1 All Stock Bike Makes- 75 HP, 70 ft lbs torque
Another JET build. This is flyboy's 88 incher:
Old 23rd May 2013
Here is a Hammer Build from their website:
1999 Buell X1 owned by Dale Nillis
Hammer Performance/Axtell Cast Iron 88 Inch Kit
Hammer Performance Sledge Head Porting Service on Buell XB Heads
S&S 600 cams
Force Big Bore Exhaust
Dyno tuned using ECM Spy by Max at High Country Harley Davidson
Dale set out to pound his competition, and the result is a fire-breathing 125 horsepower Buell X1! He got that result using an 88 Inch Kit and Sledge Head Porting service from Hammer Performance. A set of S&S 600 cams handles the valve motion and a Force Big Bore exhaust handles the exhausting chores. Be careful if you challenge Dale to a race, you're liable to be crushed!
I believe this was a high compression race gas motor.
Old 23rd July 2013
This is from user CURARE. Here's what he said when he posted it:
Cycle shack duals exhaust,
modified Cv carb. (Wood modified rebel 41.5)
very short duration cams, .630 lift
Old 28th July 2013
aswracing's Avatar
A Million Facts & Figures
2006 XL1200C owned by Bob Thompson
HAMMER PERFORMANCE/Axtell 90ci Engine Kit with 30 Degree Reverse Dome Pistons
HAMMER PERFOMANCE "SLEDGE" Head Porting Service
HAMMER PERFORMANCE "CRUSH 600" Cams
Mikuni HSR48 Carburetor
HAMMER PERFORMANCE Billet Intake Manifold
Patriot Defender Exhaust System
Dynatek DSPT-1 Ignition
Arlen Ness Air Cleaner
(being held back big time by 2 things ...)
Click Here to Contact Me
Old 28th July 2013
Dakin Engineering Dakin Engineering is offline
Sportster/Buell Year: 1987
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1991
Other Motorcycle Year: 1995
Dakin Engineering has disabled reputation
From 2001;
Draw thru carb'd
Sam
Old 24th September 2013
Here is an unique one. Its user "chevelle" 's 92ci dual carb Sputh headed ironhead sportster:
