0 headlamp housing cracked again
Last Post: eddie XLX
0 Muffler adventure and Uh-oh
Last Post: Andy56
0 possible slipping in drivetrain. looking for help
Last Post: Jfart
0 Old man walks back into a forum..
Last Post: lostNdallas
0 Allegheny 2023
Last Post: 4634indian
0 72 xlch is overcharging... bosch mechanical reg
Last Post: DR DICK
0 Would I REALLY Buy A Pan American?
Last Post: tvon
0 Solo Seat T Question
Last Post: boonoorong
14 What made the best Improvement to your Sporty??
Last Post: Dusz
0 Wiring tachometer
0 Gearing Question
0 Kelly Blue Book
Last Post: Andy Hog
0 New to an XL
Last Post: WillFrantz
0 How could a simple points change go so wrong
Last Post: ericfreeman
Last Post: 061275r
0 When Were You Born?
0 Generator Blues
9 Help: 78-83' V-Twin Front Right Caliper and 74-77' Russell 51'' Brake Line
0 First XL - XLCH or XLS?
0 83 frame early 84 motor
Last Post: 84bobber
14 Normany Beach:
HARLEYBOB1200 (71), jmw (70), Bstrdbike (70), TheCopperCowboy, Denzone (54), Wreck, mlrkar (48), acrux (36)
drum, front, ironhead, spacing, wheel
Old 7th July 2022
scotty_b's Avatar
scotty_b scotty_b is offline
Sportster/Buell Model: '03 Sportster chopper
Sportster/Buell Year: 03
scotty_b is an unknown quantity at this point
Question 1971 Ironhead front drum wheel / axle spacing
Hi, this is my first post. I am building a 33.4mm front end. I have the original trees, tubes, fork sliders, and hamburger wheel. I'd like to know the size of the stock right side axle spacer. The one that goes between the brake drum backing plate and the fork lower. The left side is spaced by sliding the fat right side of the axle in or out.
Thank you!!!
Old 7th July 2022
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Might help. Good luck.
http://sportsterpedia.com/doku.php/techtalk:ih:wheels01
I don't know off top of my head. I see a lot of ????? in the 1973 section when it comes to spacer sizes.
Edit: Might tell the moderators here to move this thread to the ironhead section. That is where the short frame 900 forum members hang out.
http://xlforum.net/forums/showthread.php?p=5720388
Traveled to
Old 7th July 2022
scotty_b's Avatar
Hey rokytnji,
thank you for replying! Please correct me if I'm wrong but I believe that 1973 is when the MoCo switched to 35mm forks which changes everything. Thanks for the tip, I'll message the moderator.
Old 8th July 2022
Sportster/Buell Year: 1971
Other Motorcycle Model: 1988 BMW K75
Whitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond reputeWhitewalls has a reputation beyond repute
There is no right side spacer indicated in the Factory parts manual. My '71 right lower fork goes against the brake backing plate. There is a grease retainer part # 43636-52.
Old 8th July 2022
rokytnji's Avatar
I was just pointing to the relevant sportspedia page for ya.
You can use sportspedia and ronnies parts finder to answer a lot of questions you may have later on.
Though ronnies does not go back as far as 1971
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
Old 9th July 2022
scotty_b's Avatar
delete please
Old 9th July 2022
scotty_b's Avatar
Whitewalls,
thank you for confirming this! I pushed the wheel against the ride side fork lower and let the left side "float" in to where it needed to be to keep the forks parallel and everything looks centered and works great. I didn't notice how much the backing plate protruded to the right before but now it makes sense that there is no spacer. Thanks again!
~scott B.
