0 timing troubles!
Last Post: JSH
0 XL883L 2006 coughing and backfiring
Last Post: Barnoff
0 1981 basket- restomod questions
0 Mustang's new seat? Anyone tried it?
Last Post: Adam76
Last Post: 1977iron
0 Who's still riding???
Last Post: 1977iron
0 Bushing alignment
0 Helmet poll
Last Post: Bama Lee XLC
0 Pull cam cover for powder coating
0 68 xlch wiring
Last Post: drumbrake
0 Celebrating Sportsterpedia's Third Anniversary
Last Post: spoon
5 Jiffy Standing
Last Post: rurlndum
0 Mid or forward controls.
Last Post: 5mel42
0 Is this 1200R worth $4500?
Last Post: rich56
0 which plug for dual plug heads
0 In Tank Oil Filter?
Last Post: maverick31210
0 Accel shafts?
Last Post: kmul
0 Winter Storm Warning
Last Post: Adam76
5 Oil pump pressure
steve yorke (61), edman (53), Hudsonator (51), kozman32 (51), R3DN3X (49), gmcsid (48), mitch (43), Gotenfan (29)
  #101
Old 19th June 2018
Dave L's Avatar
Dave L Dave L is offline
Sportster/Buell Year: 1985
Sportster/Buell Year #2: 1985
Other Motorcycle Model: Kawasaki Vulcan 700
Other Motorcycle Year: 1985
Dave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant future
I'm confused. Two wires go to my coil from a single pickup Dyna S. So this means both fire at the same time. One with valves closed the other with exhaust valve open. So a dual fire would fire only on closed valves alternating cylinders using a split coil. Sounds better to me.
Old 8th November 2018
Pezed's Avatar
Pezed Pezed is offline
Sportster/Buell Model: '77' xlch
Sportster/Buell Year: 77
Pezed has a spectacular aura aboutPezed has a spectacular aura aboutPezed has a spectacular aura aboutPezed has a spectacular aura aboutPezed has a spectacular aura aboutPezed has a spectacular aura aboutPezed has a spectacular aura aboutPezed has a spectacular aura aboutPezed has a spectacular aura aboutPezed has a spectacular aura about
General piece of information, radial engines always have an odd number of cylinders. That prevents any two cylinders being in direct opposition at any moment in time. I was taught that many years ago, but have never tried to prove or disprove it as a fact.
Better a bottle in front of me than a frontal lobotomy.
Folkie Folkie is offline
According to Wikipedia:
Four stroke radials have an odd number of cylinders per row, so that a consistent every-other-piston firing order can be maintained, providing smooth operation. For example, on a five cylinder engine the firing order is 1, 3, 5, 2, 4, and back to cylinder 1. Moreover, this always leaves a one piston gap between the piston on its combustion stroke and the piston on compression. The active stroke directly helps compress the next cylinder to fire, making the motion more uniform. If an even number of cylinders were used, an equally timed firing cycle would not be feasible.
