0 Do people notice your bike?
5 '77 ironhead fork neck cup conversion internal steering stop
Last Post: Slytat
0 Spectro STL 75W140
Last Post: DéDé
0 2 into 1 exhaust build
5 Why Are You Still Married?
Last Post: oupa
0 How do you upshift?
0 Hoo rah for Missouri.
0 03 sportster front muffler Stud nut Thread size?
Last Post: gravydog
Last Post: ReddTigger
0 Cv carb jet question
0 900 dual carb front head
0 exhaust or cams?
Last Post: wrkdWS6
0 Oil Analysis?
Last Post: Bwf347
Last Post: oupa
Last Post: Four Speed
Last Post: spacecoast
Last Post: 83XLX
0 The Multi-tool thread
Last Post: gpydeski
0 S.Y.B. Next to a waterfall.....
Last Post: Lone Rider
0 new heads
Last Post: gpydeski
0 Runs rough on highway.
  #51
Old 8th November 2018
Gary E's Avatar
Gary E Gary E is offline
Sportster/Buell Model: Flat Track
Sportster/Buell Year: 1989
Other Motorcycle Model: 6 BSA's
Gary E has a brilliant futureGary E has a brilliant futureGary E has a brilliant futureGary E has a brilliant futureGary E has a brilliant futureGary E has a brilliant futureGary E has a brilliant futureGary E has a brilliant futureGary E has a brilliant futureGary E has a brilliant futureGary E has a brilliant future
Ronnies shows a price ?
Yes they do, but they don't have them. I got a "cancel - no have" from them after I submitted an order.
rocketmangb's Avatar
have your local deealer run a nationwide search
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Gary E's Avatar
Been there done that, they won't do it.
Sportster/Buell Year: 1991
I'd report that to HD Customer Service, not very customer friendly.
It's all about CX (customer experience) today!
John
Four Speed Four Speed is online now
Sportster/Buell Year: 1988
Well, that didn't take long. Got a notice that the supplier does not have the umbrella valve.
Yep and sadly a nationwide search often just shows who hasn't updated their stock itinerary on a nation-wide basis.
Ask me how I know! At least with the umbrella valve there are viable aftermarket options if yours has died. I did
manage to find a NOS 88-90 pinion gear on eBay Canada, so don't give up on your quest just yet Gary E.
I notice that the 26856-89 Bustert mentioned seems to be sold in pairs, which suggests it is the later head breather valves?
I suspect the single umbrella valve in our engines is larger but I have not had both side by side. It would be useful to get
confirmation either way.
Gary E's Avatar
I need someone in Europe to get it from JW Boon, then send it to me.
Mine hasn't died...yet. When it comes to vintage MC's, cars, and other, I'm big on planning for the future for when a part might decide to give up. I've got 6 vintage BSA's, a vintage Mini Cooper, and a 1942 WWII carbon arc searchlight. As a result, I'm always looking.
Yep, hence my spare pinion gear! I would also plan on getting in a good stock of transmission parts.
I am in Europe but Boon normally ask for a minimum order of €75-100.
Gary E's Avatar
Well, that a start. 75-100 Euro would be about $85 to $114 USD. Let's see, what else do I need that would get me there.
WOW!
Now I really want to see a pic of it.
sheez....
Old 9th November 2018
I just Googled "industrial umbrella valve" and got several sources. Maybe contact this company if you can take some measurements? Since yours is still good, might be wise to check commercial sources. Sounds like you have plenty of time. Hell, buy 100 and corner the market on Ebay!!!
http://www.minivalve.com/newsite/ind.../how-they-work
I'd bet you can find some kind of equivalent valve with just a bit of work.
John
