0 so it's officially ended
Last Post: Cablejudge
0 Sportster book
Last Post: LLOYD883
Last Post: LLOYD883
0 AGM battery for 76' XLH
Last Post: ChiliK
Last Post: Clevspeed
Last Post: Nicktater
0 What jets do you use?
Last Post: Thack
0 My 08' Nightster
Last Post: XL1275
Last Post: XL1275
0 front brake caliper interchange question
Last Post: Seek4aws
moe (76), demgdaj (70), Playtoe (65), shanneba, Charlie Allen (61), the cowboy way (61), P-Diddly (58), Utahsporty (57), evo-pete (56), stf420 (55), NevadaRob (53), Punisher (51), Razor_Reznor (46), Paycheck (43), jfs92579 (41)
Akdawg Akdawg is offline
Sportster/Buell Year: 1969
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1969
Other Motorcycle Model: Triumph 750 tracker
Akdawg has much to be proud ofAkdawg has much to be proud ofAkdawg has much to be proud ofAkdawg has much to be proud ofAkdawg has much to be proud ofAkdawg has much to be proud ofAkdawg has much to be proud ofAkdawg has much to be proud ofAkdawg has much to be proud ofAkdawg has much to be proud ofAkdawg has much to be proud of
surely it isn't the same engine in both frames, horizontal and vertical cranks???
No, he cut the Honda in half to use the tranny with the Briggs motor.
Support your local ABATE
The number of kicks required to start a sporty are in direct relationship to the number of people watching.
Bigshankhank Bigshankhank is offline
Sportster/Buell Model: Ironhead Hardtail
Other Motorcycle Model: KTM Duke 390
Bigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant futureBigshankhank has a brilliant future
For some dumb reason there is a youtube trend going around of people putting those Harbor Freight Predator engines in everything "just because". Watched one a few months ago of a kid who put one in an old Dodge D-50 (or maybe a Mitsubishi) compact pickup. It work, drove around turned and stopped. However the jackshaft and everything else needed to make it work just don't make sense, when you consider the level of effort.
https://youtu.be/BaeyVlkLCv0
