0 Dipstick dilemma
Last Post: 11B40
0 83 XLH w/Velorex 562
0 Improving Fuel Mileage
0 We all need a laugh in these dark times
0 Gen Light stays on
Last Post: roccus
0 2021 2nd. Annual Midwest M&G
2 how much have you spent on your bike so far?
3 Wtb, Wts, Wtt, Wtg (Buells)
3 Wtb, Wts, Wtt, Wtg (XRs)
3 Wtb, Wts, Wtt, Wtg (Rubber Mounts)
3 Wtb, Wts, Wtt, Wtg (EFIs)
Last Post: HawkeyeTX
3 Wtb, Wts, Wtt, Wtg (Evos)
0 Identity crisis
0 WTB 14" covered rear shocks
Last Post: Doc308
0 That Stupid F@#$&in' Speedometer
Last Post: casual_obser
0 S&S to CV Manifold Flange Adapter
0 BEWARE Of SCAMMERS!
Taipan (62), Harveyveepower (61), regoscar (52), kmm0000 (46), SmokeyDrifter (38)
Closed Thread
Old 24th September 2015
Default Provide This Info When Asking About Tuning Carb'd Models
In order for the forum members to provide quality advice, it is important
that you provide quality information about the build of your bike. You can
simply select & copy the following list into your original posting of a
question
and then replace the ???? with the correct information so
that members know what you know about your bike.
For TUNING of CV40 carburetored EVOs (1988-2006), the following
information is relevant:
Engine Size ----------- ???? (Stock 883, Stock 1200, Conv883-1200, Conv883-1250, etc.)
Heads Installed ------- ???? (Stock 883, Stock 1200, Specify Brand/Model)
Cam Installed --------- ???? (Stock D, Stock W, Specify Brand/Model)
Ignition Module ------- ???? (Stock 883, Stock 1200, Specify Brand/Model#)
VOES being used ----- ???? Y / N - Was it checked for operation?
VOES Vacuum Mod'd -- ???? Y / N - (Specify what Switch Point)
Air Cleaner ----------- ???? (Stock, Specify Brand/Model)
Head Venting Into Carb ???? Y / N
Exhaust -------------- ???? (Stock, Specify Brand/Model/Baffles/TqCones)
Spark Plugs Used ------ ???? (Stock, Specify Brand/Model#)
What Model Carb ----- ???? (Stock CV, Specify Brand/Model)
Check for Intake Leak - ???? Y / N - Unlit propane torch near manifold ports
Inside of CV Carburetor:
Slow Jet -------------- ???? (Stock, Specify Known Size)
Idle Mixture Screw ---- ???? set at xxx turns from lite seat
IMS set by Idle Drop -- ???? Y / N - Did you set it?
Drilled Slide? ---------- ???? Y / N - Based on who's recomm.
Altered Slide Spring? -- ???? Y / N - Based on who's recomm.
Jet Needle ------------ ???? (Stock, DJ, Other Keihin, Specify Brand/#)
Emulsion Tube -------- ???? (Stock, DJ, Specify Known Brand/#)
Main Jet -------------- ???? (Stock, Specify Known Brand/Size#)
Fuel Float Level Set --- ???? Y / N (Stock, Other)
Fuel Float Valve ------- ???? Y / N - Cleaned & Checked
Provide Pictures of Spark Plugs
Used Chop Method ---- ???? Y / N
............ At Idle (Frt,Rr)
............ At Mid-Range (Frt,Rr)
............ At Wide Open Throttle (Frt,Rr)
IXL 2 Relax
>>>> My Build & Ride Reports Are Here <<<<
Reference the Sportsterpedia
An XLForum collection of technical info & advice
brianbbs67's Avatar
Reformed Savant
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 1970
Other Motorcycle Year: 1977
It is a good idea. Plug and play. Bump
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
You forgot the most important question. Is your carb stock or after market?
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Fair enough - added....
IXL 2 Relax
fendetestas's Avatar
fendetestas fendetestas is offline
Sportster/Buell Model: 883L
fendetestas is a name known to allfendetestas is a name known to allfendetestas is a name known to allfendetestas is a name known to allfendetestas is a name known to allfendetestas is a name known to allfendetestas is a name known to allfendetestas is a name known to allfendetestas is a name known to allfendetestas is a name known to allfendetestas is a name known to all
Yes please, a sticky on this.
Maybe better on section : SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Intake and Exhaust > Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust
Old 15th December 2015
Tuning the Carb for the Bike:
No matter where you start, you still have to tune the carb to the bike - there's no magic formula to implement - it requires that you observe the bike's performance and examine the plugs - then make changes accordingly...
You can get jets at your local HD in most cases - getting a particular needle may be a little more difficult from HD - and HD has no easy-reach Idle Mixture Screw options... CV Performance has been a good source for all of these as well...
Definitely stay away from the DynoJet kits... Save your money and the headaches...
I like starting at a point close to where others have found the right tune - It doesn't take the place of plug reading and tuning, but it will give you a starting boost toward the right setting...
If you have upgraded your air cleaner & exhausts, I'm almost certain the 42 Slow Jet will need to be increased to 44 or 45 - Based on many previous reports, most 1200's idle and transition better with a 45 Slow Jet (some with a 46)...
A 175 or 180 Main (on a 1200/1250) should be a good starting point...
Needles are mostly mid-range critical (you can shim most any needle to help the lowest end if necessary)... But the subtle changes that the needle makes in the mid-range may call for careful analysis to get the right one... Many of the 90's 1200's relied on the N65C to get close to the desired goal...
Your stock needle may be just fine as a starting point... You'll have to check your low- and mid-range performance to determine whether a replacement needle is necessary or whether shimming what you have will be sufficient...
It's not rocket science - If you pay attention to the engine sounds and performance, take spark plug readings (chops), and get a little coaching from the forum, you should be able to get the right parts and make the right adjustments to be happy with it's performance...
IXL 2 Relax
Closed Thread
