0 Clutch issue
0 Bendix / Zenith questions
Last Post: DirtyHarry68
0 little rock
0 Suzuki's Radar Reflector Idea
Last Post: tedg
0 New acquisition
0 Ignition question
Last Post: Anti-Hero
Last Post: paulc
5 Summer time heat
0 79 Tranny
0 R.I.P. Arlen Ness
Last Post: oupa
Last Post: moparnut72
0 Have you taken your “dumbass pill” today?
0 883 to 1250 is done
0 883N brake/signal problem
0 I'm going nuts (Adjusting Fuel Mixture)
0 How long for the XL Member patch?
Last Post: bdawson
0 mid controls
Last Post: whetrick1
0 Really Hard to start XL1200 C
Last Post: farmall
Last Post: Lone Rider
0 Front cylinder noise
0 900 dual carb front head
0 Tried starting the bike this morning, batter charged, but bike wont turnover?
Last Post: clc1989
0 1200S cam comparisons
Last Post: Saint666
mike, Rick572 (72), Tailchaser (71), Back Road (55), sanman12002003 (54), LilMsRida (54), wargod1 (50), tplyons (32), DOM! (31)
racemoto's Avatar
racemoto racemoto is offline
racemoto is an unknown quantity at this point
Default Need recommendations for 17"/18" Wheels (or maybe 19..)
Hey,
I am planning to modify my 1200C towards being a Flat Tracker over time - with the wheels being one of the main things, obviously: the custom has 16/21 now and that's not the right direction... :-)
I understand AMA requires 19" and therefore the "real thing" would ne 19 inch - but but after a bit of research, it seems I'd have way more tire options when going with the popular size 17" (and still with 18").
Does anyone here have a recommendation for the most affordable wheels? (Spokes or Cast wheels - I have a preference, but affordability would supersede that.
I researched a bit and it seems one can spend anything between 180-ish and 1,000 per Wheel (!).
Not sure how to choose, not sure how they differ - and would love to get some advice before I go ahead and simply buy the cheapest I can get...
Thanks for your help!
jkinkade jkinkade is offline
RaceMoto, I like the flat tracker style too!
I would lace 18" rim's front & rear if I was doing it,
Good luck with project!
2003 XL 88"
Edster's Avatar
Edster Edster is offline
Edster is a splendid one to beholdEdster is a splendid one to beholdEdster is a splendid one to beholdEdster is a splendid one to beholdEdster is a splendid one to beholdEdster is a splendid one to beholdEdster is a splendid one to beholdEdster is a splendid one to beholdEdster is a splendid one to beholdEdster is a splendid one to beholdEdster is a splendid one to behold
I've been toying with the same idea as well. I prefer to have mags or cast aluminum. However, economically reasonable options are few. The old Morrison mags can be found but fitment seems to be an issue for the rear as it appears that the rears are drum only and the fronts are single disc. I have an S model and would like to keep the dual discs.
Sent from my LG-TP260 using Tapatalk
Matt Black Matt Black is offline
Matt Black has much to be proud ofMatt Black has much to be proud ofMatt Black has much to be proud ofMatt Black has much to be proud ofMatt Black has much to be proud ofMatt Black has much to be proud ofMatt Black has much to be proud ofMatt Black has much to be proud ofMatt Black has much to be proud ofMatt Black has much to be proud ofMatt Black has much to be proud of
You could get a rear hub from a laced wheel and lace it to a front 19in rim. Call up Buchanan and they can do any combination of things from selling you a 19in rim and spokes to use with your rear hub to building the whole thing for you.
Or, I just bought a Moto Iron 18in rear from TC Bros, they have a 19 as well.
Build thread: http://xlforum.net/forums/showthread.php?t=2030965
racemoto's Avatar
Thanks, will check!
Nibelungen's Avatar
Bike Builder
definitely... at least 18" rear 19" front... but better both 18" (150 or 130 the rear and 100 or 120 the front one)...
racemoto's Avatar
Hmmm..
From the optical standpoint, 18" or 19" makes more sense, indeed.
But looking the the tire options, 17" is a completely different story...
