Last Post: Bored now
0 15 min rides
Last Post: CMCSSeabee
0 Range With EFI 3.3 Gal Tank
Last Post: corndog76
0 back to factory clutch
Last Post: Mark Jags
0 Branch Mikuni Air cleaner question
0 Resto-Repair 84 ironhead
Last Post: lynnx
0 1960 XLCH in the UK
Last Post: lynnx
Last Post: Guidorey
0 E85 Fuel
Last Post: hondo
Last Post: fafcpa
Last Post: fafcpa
0 Replacement Clutch/Rotor Magnets
0 97 Sportster Kickstand Problem
Last Post: Dirt Road Cowboy
0 removing clear coat on fork lowers
0 HELP! Extra part found
Last Post: syrnetworkin
0 48 O2 sensor?
Last Post: jvandivere
0 Starting issues (No Spark)
Last Post: jimstogs
0 The forum got talent
0 Battery melt down
0 Common ironhead problems
0 Hello from Tampa, Fl
0 Getting Hammered
Last Post: Bryan1976
0 Greetings from Denmark
exhaust, screaming eagle, slipons, stock, vance and hines
Old 28th April 2019
Billy The Kiddo's Avatar
Billy The Kiddo Billy The Kiddo is offline
Sportster/Buell Model: Sporster XL1200C
Billy The Kiddo is a splendid one to beholdBilly The Kiddo is a splendid one to beholdBilly The Kiddo is a splendid one to beholdBilly The Kiddo is a splendid one to beholdBilly The Kiddo is a splendid one to beholdBilly The Kiddo is a splendid one to beholdBilly The Kiddo is a splendid one to beholdBilly The Kiddo is a splendid one to beholdBilly The Kiddo is a splendid one to beholdBilly The Kiddo is a splendid one to beholdBilly The Kiddo is a splendid one to behold
Default Stock exhaust with screaming eagles slipons?
Hey guys and gals!! Took these off over the weekend and I was wondering if they are stock exhaust with screaming eagle slipons or a whole exhaust. Put on some V&H's and was prob going to try to get rid of these but not sure what to advertise them as.. thanx in advance!
https://ibb.co/gVyy3GV https://ibb.co/44P5tn0 https://ibb.co/VDDJ2rw https://ibb.co/KLnMSqb
Last edited by Billy The Kiddo; 28th April 2019 at 08:30.. Reason: Pictures didnt show
Old 28th April 2019
Folkie Folkie is offline
Your pictures are, unfortunately, absolutely massive, but here they are as thumbnails:
Old 28th April 2019
Forr some reason i can see those but the ones I posted aren't showing up for me.. Thanx!!
Old 28th April 2019
That's because you used the URLs of the pages that the pics were on, not of the pics themselves, but posted them as if they were pics. The easiest way is to copy the 'Embed Code' (eg: 'Thumbnail image (linked): BBCode', especially if your pic is large), and paste that into your post.
If your pic is a reasonable size (say: no more than about 1024 × 693 pixels), then you can use the 'Full image: BBCode' embed code, and the pic will display full size in your post.
Old 28th April 2019
Gotcha.... thanx again
Old 28th April 2019
Sportster/Buell Year: 1991
Look like stock exhaust with Screamin' Beagle slip ons. They make good power in that combination from what I've read. I have the same on my bike except the marks are Harley-Davidson instead of SE. I think mine are an early version.
John
Old 28th April 2019
RussW RussW is offline
Sportster/Buell Model: Hugger
Other Motorcycle Model: Panhead
Other Motorcycle Year: 1961
RussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant futureRussW has a brilliant future
Like noted, stock exhaust with a set of "XL Slip-fit Torque Mufflers". (#80051-00) All the other SE mufflers had different end cuts. The ones marked with "Harley Davidson" were the 49 state street legal SE mufflers, the ones with the "Screaming Eagle" logo were race only. Keeping an old HD catalogue from 2004 comes in handy.
2002 Hugger, S&S 1200 conversion, Woods cam,SE ignition/coil, D&D Fat Cat
Old 1st May 2019
Thanx Russ!! I never throw things like that away either...
