Last Post: darwin-t
0 Wild Crap Going on Today On My Ride
Last Post: XL1275
0 Kick starter resistance
Last Post: metal88
0 Kicker shaft question
Last Post: Captain Johnny
0 Question for Jorgen, Aaron, ???
Last Post: 1200CustomHD
Last Post: the cowboy way
0 tapped adjust
0 19" Tire w/23" Overall Diameter???
Last Post: XL1275
0 Starter solenoid short
Last Post: Bwf347
5 Request advice - Engine knock above 2800rpm
Last Post: XL Dane
Last Post: Billy1200
0 The salty debate thread.
0 Sportster engine wt.
0 Why Torx?
Last Post: Hellbent_4
0 Town Bike Handlebar Styling
0 WTF Happened
0 EFI Sporty Hanging Revs
Last Post: gwd1994
0 Hello
0 Range With EFI 3.3 Gal Tank
ziggyhd1 (62), MikeDelta (62), greven (60), bliynd (35), Steveb1990 (30)
bushings, handlebar, numb, poly, vibration
Old 11th August 2019
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
Default More handlebar vibration with poly bushings???
Should be “With” poly...
My 1996 has always had considerable handle bar vibration. I had replaced the worn bushings with rubber a year ago and it helped a little.
My bars were the OEM originals, with 4.5” straight risers and GT grips.
I just changed the setup to Chump style bars (short mini narrow apes) short risers and red poly bushings, same GT grips.
The handle bar vibration is just BRUTAL. I just went out for a one hour ride and came back with numb white fingers in 80 degree F weather.
I think the riser bushing are isolated, the washers aren’t touching the triple tree or anything like that. IDK if it’s the bushings or the bars, or both.
I just read some of this thread and am considering some of the mods. The thread is 10 years old though.
http://xlforum.net/forums/showthread.php?t=448758
Do you folks have any comment or suggestions?
A traditional "fix" is bar end weights. Just a piece of steel round stock slid into the bar end and welded. We'd save crash damaged bars with weights so we could cut the welds and re-use the weights in bars that didn't come with them.
If you do a search for "bar end weights" you'll find the aftermarket has lots of different flavors available.
harley506d's Avatar
Sportster/Buell Model: 1200c
Go back to stock rubber type!
I would think hard poly bushes are a no-no.
Old 12th August 2019
mikeLI_77's Avatar
The poly bushings made the vibrations much better on my bike going from the stock drag cars to carlini t bars that are 32" wide 6"rise and 4" pullback.
Some people have glued rolls of pennies in there bar ends to help the issue your having many use the vibrinators sold by ricor.
2002 XL1200C (originally)
Dyno Sheet
96.21 HP/88.70 TQ
States I Have rode through
Old 31st August 2019
Maxeffort's Avatar
I installed a 6" lenth of 3/4" mild steel bar into each handle bar end. Still had numb fingers after one hour.
I reinstalled the rubber Bushings (one year old) and now it's better then it ever was with the combo of rubber and weight. A three hour ride today was ok.
The urethane bushings I put in are very hard. They might as well be solid hard nylon. I see the urethane bushings Harley sells are "37 percent stiffer than stock". The red urethane bushings that I installed are like 200% stiffer than stock.
I'm glad to have my flexi handlebars back!
