0 Ceramic Coating My Paint
0 Hello from New York
Last Post: oreocat1
0 Hi from Calgary
Last Post: oreocat1
0 crank case breather
Last Post: Jollly Rogers
0 Ride Report for the 2019 Void rally
0 Flame's New 1989
0 1960 XLCH in the UK
Last Post: soundnav
0 It’s Glamazon’s Birthday!
0 Bike sold leaving forum
0 570's or 536, 560's @10:1 Compression
Last Post: Bikeaholic
0 Battery/regualtor/charging strange problem
0 Spokes or Mags
Last Post: 51 New West
0 40mm CV vs. S&S Super E for Draw thought Turbo!
4 The no-debate OIL POLL
Last Post: Boil1337
0 Rico Lutsey aka Rico 05R
Last Post: rubine
0 Carburetor opinions
0 Mid West Meet & Greet
Last Post: MatHormell
jdhickm (84), Chip (71), Chief4x4 (69), willyobiker (67), CBryant (66), XLCH69 (63), sage (60), Butch (60), VettesRule (57), jerseyjeff (57), TheExecutioner (54), SalTheWop (54), manic_mechanic, pauldmedic16 (45), BluegrassXL (41), Superman
Old 27th March 2019
spitfirechopper's Avatar
spitfirechopper spitfirechopper is offline
Sportster/Buell Model: ironhead xlx
Sportster/Buell Year: 1983
Sportster/Buell Year #2: 2005
spitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud ofspitfirechopper has much to be proud of
Default Starting woes :(
Evening/morning all
2005xl1200C
When i first got her the girl wouldn't start for shit, push the button, CLANK, and then a slow turn over.
I replaced the starter with an all balls 1.4KW, and a new battery from HD.
She spun right up for about two years, sounding healthy.
I could do the usual bar runs on the weekend, not more than 20 miles between, at least 5 stops and always she would fire up with no hesitation.
But here we are now, i'm getting the same hesitation when pushing the starter, push starter, you can tell it's trying to push past compression, then bam she fires up. I can do this maybe 4-5 times on a fresh battery until it's toast. During this the headlight and speedo go out completely.
Sometimes fires up like a mad dog, completely forgets it's trying to play dead.
Running regular 20-50 dino oil, have tried with clutch pulled in, same hesitation.
Rebuilt starter.
Went through all solenoids/fuses, cleaned and freshened up terminals.
New ground leads, positive is still in mint condition so not changed.
Brand new battery, charged up to full then installed, checked voltage and drop on load. All within specs.
What the hell is going on?
Any input welcomed
Old 27th March 2019
do current draw test on starter
charge battery and do two back to back amp draw tests, the first is to remove surface charge and the second to see what it is actually doing, do not allow too much time between tests and the battery will try to recover and give a false reading.
check your charge circuit and ground.
what do you consider rebuild on starter?
Old 27th March 2019
sportsterdoc's Avatar
Confirm both ends of both battery cables removed, cleaned, wire brushed, reconnected?
Same question as BusterT re rebuilt starter: Rebuilding starter included new solenoid contacts, new brushes, commutator turned and undercut, new bearings?
What was battery voltage while attempting to crank?
Old 27th March 2019
When you're having issues with the electrical system, use this Sportsterpedia section about checking the battery cables, voltages and grounds -
DO THIS BEFORE ANYTHING ELSE:
Please report your SPECIFIC METER READINGS from those tests...
Be sure to remove, clean & anti-seize the Powertrain Ground !
Be Patient, Be Accurate, Be Methodical & Be Thorough...
Long-distance diagnostics requires lots of accurate and specific information so that 'WE SEE' what you see... and maybe see what you don't see...
General Diagnostics - Including Won't Turn Over & Won't Start
http://sportsterpedia.com/doku.php/t...k:ref:genmsr01
It's unlikely the starter/solenoid, but here's that section of the SP:
http://sportsterpedia.com/doku.php/t...enoid_assembly
Check The Sportsterpedia - The Best Kept Secret on the XLForum!
Old 27th March 2019
Yep cables looking like new after a good clean.
Starter was taken to a shop and rebuilt with them all the way down to the bearings, comm, the works.
I will double check voltage drop on cranking
Old 16th September 2019
roksngr's Avatar
roksngr roksngr is offline
Sportster/Buell Model: XL1200 C
roksngr is an unknown quantity at this point
I'm having exact same problem, I have replaced with all balls starter, new cables, new battery and new starter relay...still wont crank over. I am really getting sick of this. I guess I need to tow it in to the shop.
oldboy's Avatar
oldboy oldboy is offline
Other Motorcycle Year: 1974
Sounds like it's time to look into the solenoid and inspect the contacts and ring.
Do you hear the 'clank' noise (at the solenoid) when you hit the start button? Or only the 'click' of the relay?
Does the starter try to turn the engine?
Without the spark plugs in, does it turn the engine over?
Old 18th September 2019
Cleaning the cables may not help if corrosion has gotten inside the sheath.
mwXL 2006's Avatar
mwXL 2006 mwXL 2006 is offline
Sportster/Buell Model: xl 1200c custom
mwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to behold
Originally Posted by spitfirechopper View Post
Evening/morning all
2005xl1200C
Rebuilt starter.
Any input welcomed
stock starter pulls .875 kw according to my research when I put a 1.4 kw in
I see no mention of cables being replaced with required #4 AWG size multi-strand battery cables. Stock cables are # 6 AWG. All Balls states this. The draw from the 1.4 starter is very high to start engine. Put DVM on battery and verify when starting. No mention of battery tender either. Should stay around 10 Volts when starting. Short runs may not be helping battery to become completely charged. 2 years on starter not right. IMO Proper torque on cables and some dielectric grease will help keep corrosion at minimum. Heat shrink the lug ends of the cables to help keep moisture out also. watching this one.
Xl 1200c custom 2006 carb.
42 CVP pilot 180 main
3 out a/f screw
V&H straightshot slip-ons
K&N Hi-Flow 587 air cleaner
Breather Bolts to air
Love to ride. Stay safe
Milt
http://sportsterpedia.com/doku.php/start Use it great info
https://postimages.org/ for your photos
