Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > VENDORS > CV Performance
Last Post: 83XLX
0 Carburetor opinions
0 ***DK Custom Products Outlaw Permanent HiFlow Reusable Oil Filter***
0 Are 2003-prior cams and cover a bolt-on swap?
Last Post: farmall
0 1960 XLCH in the UK
0 hot start and starter "coughs"
Last Post: clnsflknr
0 Clutch cable deal
0 C&C Solo Seat comfort?
0 Fuel Injection cleaner
Last Post: farmall
12 air leak from intake
0 A Day in the Life...
0 570's or 536, 560's @10:1 Compression
0 When Were You Born?
Last Post: Joe_jeep
Last Post: Wilkinson949
0 crank case breather
0 40mm CV vs. S&S Super E for Draw thought Turbo!
Last Post: MonkeyMadness
0 Bike sold leaving forum
Last Post: 11alan111
0 *DK Custom - M8 Softail Passenger Pegs - Now You Have Options - Intro Savings*
0 Ride Report for the 2019 Void rally
Last Post: Coop802
0 My new LED headlight
Old 25th July 2011
CVPerformance CVPerformance is offline
Sportster/Buell Model: XLH 883>1200
Sportster/Buell Year: 1988
Other Motorcycle Model: FXE
Other Motorcycle Year: 1976
CVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to beholdCVPerformance is a splendid one to behold
Arrow N65C Needle Reintroduced
As many are aware the original N65C Sportster needle (27094-88) was made obsolete several years ago when the factory discontinued them. By popular demand CV Performance has reintroduced the N65C needle using our own CNC machining process found no where else. The specs of the profile and taper match those of the original and is a direct replacement.
The N65C needle was originally introduced by Keihin on the first Harley CV carburetor equipped on 1988 Sportsters. Because this first CV had no accelerator pump the needle was designed to be richer just off idle to eliminate hesitation and it used a different taper profile. Tuners soon discovered (well documented on XLF) that the N65C needle was perfect for DIY tuning when installing free-flow exhausts and air cleaners and has been a staple in performance tuning for many years.
While the other CVP needles meet the needs of specific models without wasting fuel or requiring trial and error tuning, the new CVP N65 (N65C replacement) is ideal for those who want to custom tune. The needle may be used with shims or by itself and CVP does not have specific recommendations. Please refer to the many recommendations on this forum for tuning with a N65C needle with or without shims.
XL Forum members, don't forget to use promo code xlforum10 for a 10% discount!
Old 25th July 2011
Dakin Engineering Dakin Engineering is offline
Sportster/Buell Year: 1987
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1991
Other Motorcycle Year: 1995
Dakin Engineering has disabled reputation
Installed one today.
Sam
#6062
Old 25th July 2011
trainman's Avatar
trainman trainman is offline
Which is richer off of idle the N65C or NOKK needle.
Old 25th July 2011
From everything I've seen and testing done by NRHS as well the NOKK comes in slightly faster (richer) just off idle. The original CVP needle we make for the 883 profiles similar to the NOKK in respect to the off-idle A/F.
Old 26th July 2011
Cindy Dietz's Avatar
Cindy Dietz Cindy Dietz is offline
Sportster/Buell Model: 883=>1200 Low
Cindy Dietz has a brilliant futureCindy Dietz has a brilliant futureCindy Dietz has a brilliant futureCindy Dietz has a brilliant futureCindy Dietz has a brilliant futureCindy Dietz has a brilliant futureCindy Dietz has a brilliant futureCindy Dietz has a brilliant futureCindy Dietz has a brilliant futureCindy Dietz has a brilliant futureCindy Dietz has a brilliant future
Sam
#6062
And it was bought at Worth HD in KC on Saturday. They had 3 in-stock.
Thanks Sam!
Cindy Dietz
Greensboro, NC
Effie: 2005 883=>1200 Low 191,586 miles & done
#2: 2006 1200 Low
IBA #23594
My Travel Blog
http://s844.photobucket.com/user/cindydietzks/media/Maptraveled%202006_zpsicsgyx5w.jpg.html
Old 30th August 2011
Don Burton's Avatar
Having a copy of the N65C needle still available if H-D runs out is great news! I hope that someone will copy some of the other needles when they go off the market as well.
Don Burton's Avatar
All of NRHS's publlished testing on the N65C needle that I have seen was done on an unshimmed needle at WOT and thus is largely irrelevant to the subtleties of part throttle slower street riding. If you measure the diameter of the off idle straight portion of the N65C needle you will find that it is quite a bit thinner, (richer) than the NOKK needle. However the NOKK has a significantly shorter straight portion before the taper than the N65C needle, which allows the taper to come on sooner, and which richens things up in that area sooner. You can shim the N65C for the same effect if need be.
