0 so it's officially ended
Last Post: fafcpa
Last Post: robbie202
0 Mikuni - hangin revs
0 New to me '08 1200R
Last Post: PhiRR
0 TC88A update ?
Last Post: HOG63
5 Dynatek DSPT-1 ?
Last Post: HOG63
0 Riding music
0 Xr750
Last Post: Armand
0 100 vs 110 front tire
Last Post: lehel
Last Post: CCC
Last Post: slojoe631
0 Xl???
Last Post: SD_Mike
Last Post: randy3934
Last Post: Greasyman
0 Now I did it. Feel my pain
0 old parts
0 Digital speedo from street bob on a sporty?
Last Post: yelladox
0 Starter for an XLCH
Last Post: Imaginearat
0 Hello from LA area
Last Post: initiatebjj
0 Oil not returning to tank
Last Post: 1Scooter
Last Post: Nicktater
Last Post: The Doctor71
texrex (68), jjluvstoride (55), luisbmns (50), njstoehr (44), tacho75xlh (41), 80ironhead80 (31), Xttrackerr (25)
norley workshop manx
  #271
Old 9th December 2018
Merch131ho Merch131ho is offline
Sportster/Buell Model: XL1000
Sportster/Buell Year: 1979
Other Motorcycle Model: Merch 131
Merch131ho has much to be proud ofMerch131ho has much to be proud ofMerch131ho has much to be proud ofMerch131ho has much to be proud ofMerch131ho has much to be proud ofMerch131ho has much to be proud ofMerch131ho has much to be proud ofMerch131ho has much to be proud ofMerch131ho has much to be proud ofMerch131ho has much to be proud ofMerch131ho has much to be proud of
Originally Posted by TonyGall View Post
I like your mates 1250, have you got anymore pic's ?
There is a separate thread on the bike in the Projects section.. lots of pics and links to YT vids.
TonyGall TonyGall is offline
TonyGall is an unknown quantity at this point
cheers Merch
Old 31st March 2019
Finally got the new paintwork back on the bike, along with a new front guard/fender. I had to make a pair of fork clamps to mount it the way I wanted, these are polished and don't look right on the silver fork lowers, but I'll paint them black at some point. It'll also be getting upgraded suspension this year, but need to save my pennies to pay for that.
My current big problem is the broken oil pressure sender.. I've got a new one to replace it, but cant get the broken one off the engine.. it just wont move. Not helped by the lack of access, probably worse than on a standard Ironhead. I don't want to risk starting the bike, and wrecking the engine for a lack of oil if there's a problem.
Old 3rd April 2019
Commando Commando is offline
Other Motorcycle Model: Norton Commando
Other Motorcycle Year: 1971
Commando has a spectacular aura aboutCommando has a spectacular aura aboutCommando has a spectacular aura aboutCommando has a spectacular aura aboutCommando has a spectacular aura aboutCommando has a spectacular aura aboutCommando has a spectacular aura aboutCommando has a spectacular aura aboutCommando has a spectacular aura aboutCommando has a spectacular aura aboutCommando has a spectacular aura about
Good lord, I'm in love!
Old 27th July 2019
Had lots of frustrating problems with the bike recently, mainly electrical. Its needed a new starter motor, a leaking hydraulic clutch slave cylinder and with those fixed it still wouldn't fire up. Eventually I traced the problem to a HT lead which was tracking. A simple fix I should've found it earlier.
Smoked a bit when it finally fired up, probably due to the oil I poured down the bores sometime ago.
Sounds pretty good with its reverse megaphone 'silencers' …. You can here it start for the first time in years here..
https://youtu.be/_eKwRJiZ534?t=644
Old 27th July 2019
Highly-Dangerous's Avatar
WOWW!!!
Awesome... Fantastic!!!!
I have no words......
[B][COLOR="Red"]CLICK->>[/COLOR][URL="http://sportsterpedia.com/doku.php/start"]"Maintenance is as much art as it is science"[/URL][COLOR="red"]<<-CLICK[/COLOR][/B]
[IMG]http://xlforum.net/forums/attachment.php?attachmentid=20617&d=1576580635[/IMG]
Old 27th July 2019
shoveldog's Avatar
shoveldog shoveldog is offline
Sportster/Buell Model: XL 883R
Other Motorcycle Model: 2005 FLHRCI
shoveldog is an unknown quantity at this point
Man that's bad-ass sporty.
Mike 2007 XL 883R
Old 27th July 2019
In the video I had to jump start it from my car, as the expensive Ballistic Lithium battery had failed.. not sure why, suspect being connected to the bike for several months unused drained it. Oddly both the electronic speedo and its sensor require a permanent 12V supply which could be the cause.
There isn't much room for a battery under the seat hump, and what room there is was made to fit the Ballistic. Only problem is that Ballistic company has gone bust.
Eventually I found a suitable Lithium battery of the correct size / power made by a company called Anti Gravity. At £210 it will have to wait a few weeks until I can afford to buy it.
Here's a pic from the LHS, I still want to make the gear change neater by shortening the splined lever and the foot lever by 20mm or so.. but that'll have to wait until I know the ear change feels ok in use as is..
Old 24th May 2020
Making a few simple, but expensive upgrades to the bike, that I couldn't afford when I first built it.
First on the list is suspension, I've replaced the basic YSS shocks with a pair of Hagon Nitros, custom built for the bike (and me). They arrived yesterday and went on the bike with no problems. They are 30mm longer, with firmer springs and 10 position adjustable damping. The body and spring are polished stainless steel, though I had mine with powder coated springs. Next I'll be working on the forks..
Old 25th May 2020
Damn good looking set of wheels, you’ve done an outstanding job, kudos to you!
