Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Air Intake, Carburetor/Fuel Injection, Fuel, and Exhaust
0 S&S Super E Carb
Last Post: OCRyder
0 Oil not returning to tank
0 Sportsters in movies and TV
Last Post: dodgetrucken
0 100 vs 110 front tire
0 Fair price for used parts
Last Post: rivethog
0 Mikuni - hangin revs
0 so it's officially ended
Last Post: robbie202
0 New to me '08 1200R
Last Post: PhiRR
0 TC88A update ?
Last Post: HOG63
5 Dynatek DSPT-1 ?
Last Post: HOG63
0 Riding music
0 Xr750
Last Post: Armand
Last Post: CCC
Last Post: slojoe631
0 Xl???
Last Post: SD_Mike
Last Post: randy3934
Last Post: Greasyman
0 Now I did it. Feel my pain
0 old parts
0 Digital speedo from street bob on a sporty?
Last Post: yelladox
texrex (68), jjluvstoride (55), luisbmns (50), njstoehr (44), tacho75xlh (41), 80ironhead80 (31), Xttrackerr (25)
Old 17th March 2015
nleco's Avatar
nleco nleco is offline
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1984
nleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to beholdnleco is a splendid one to behold
The bike seemed repairable. BUT it would have cost more money and time. David is a bit over having to do another bike rebuild. he's spend more time rebuilding than riding this past year.
- I think that the seat was crushed, but that is replaceable.
- the front cylinder frame mounting bolt spot broke off. That would require some welding and what not.
- Some other stuff got lost, like the ignition (i think).
- the AC and Pipe was actually ok, i dont know how.
- handlebars got slightly bent, but they were clipons.
- hand controls got scratched
- clutch pin and controls got bent.. not sure if that could have been bent back and have it be workable.
The bike frame seemed ok. But it was hard to tell if it was slightly bent or not. The rear wheel did turn, and pistons moved. We think the engine was ok. It was sad that the broken in 1250 kit is going to a junk yard when it seems perfectly good.
The most important thing though, is that David is ok. he suffered a concussion and road rash, along with maybe some muscle bruising. The bike is replaceable, even though we will miss it. But David isn't.
2009 Iron [LIST][*]1250 Hammer Kit[*]30 degree reverse dome pistons[*]1.770 7MM Intake 4.520 TG Conversion[*]1.530 7MM Exhaust 4.610 TG Conversion[*]Striker Performance 7MM Valve Spring 550 Lift Triple Grove Locks/Beehive Springs[*]Competition Valve Job[*]560 Impact Cam Set[*]Bronze Oil Pump Gear[*]Dragtron II AC[*]V&H Shortshots[/LIST]
1984 Ironhead
Old 17th March 2015
scooby scooby is offline
Sportster/Buell Model #2: FXLR
Sportster/Buell Year #2: 1988
scooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant future
Junk yard? Insurance mandated I guess?
Perhaps buying it back. Heck the motor could fetch a few grand by itself.
Old 17th March 2015
nleco's Avatar
yeah. but David was over it. and I don't blame him.
Old 18th March 2015
wedge's Avatar
wedge wedge is offline
Well, to be fair, it was not a complete engine. The primary case was smashed, and so was the derby cover. The shifter shaft was at very least bent, and we did not open it up to see if it cracked the case when it bent the shaft.
I thought it would be worth the 1300 they wanted to buy it back, but David just wanted to move on and get the Buell.
He has ordered the manual, so maybe soon we will be addressing the lag. In the meantime, the bike seems to run OK otherwise, and David is going over all the bolts and screws to make sure it's solid.
Old 18th March 2015
AB,Frank's Avatar
AB,Frank AB,Frank is offline
serial Canuckian
Sportster/Buell Model: XL1250C
AB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond repute
Dam!! I hope all of that bad shyte is behind him now!! Glad he's OK.
Hesitation on EFI's is usually from bad connections or gas,fuel filter,dirty or partially plugged injector,wires or plugs and throttle is properly adjusted....then if that didn't get it , sensors are to be tested.
but then again you're saying he's got a after market tuner on there...soooo...we would have to look at that also,maybe first off...any mechanical noises that shouldn't be there ??
In three words I can sum up everything I've learned about life: it goes on.
Old 18th March 2015
PuddlePirate's Avatar
PuddlePirate PuddlePirate is offline
Sportster/Buell Model: 883 Hugger/Buell XB12
Sportster/Buell Model #2: Electra Glide
Sportster/Buell Year #2: 2002
PuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nice
Originally Posted by Ocgreenmachine View Post
Now, as to the bike I have acquired, I haven't had the time to open it up to doublecheck the tuner. It is a 2007 xb12scg with 8000 miles. Owner said replaced with buell racing chip and stock exhaust was modified to buell racing specs by previous owner (suspect means cleaned out the inside of the stock muffler). He also said he took it to a harley dealership to get the tuner put in and tuned. I will add more when I find the time to open it up.
There's no such thing as a "Buell Chip". Maybe he means a Buell race ECM? That should be really easy to verify by just looking at it.
I have never heard of a "Buell Racing Spec" modification to a stock muffler. There was a factory race muffler, but it sounds like the one on the bike he bought was a stocker that was hacked.
Which "tuner" is installed? ECM Spy and Tunerpro (both free) are used with pretty good success. The Power Commanders aren't well liked on the XBs, and the TFIs aren't that much better. Most XB owners I know do their own tuning with ECM Spy.
I'm not an XB guy, but check this out and they may be able to answer your questions: http://www.badweatherbikers.com/buel...tml?1426686536
Your limits are self-imposed by what you let your mind believe
Old 20th March 2015
wedge's Avatar
No unusual noises. We listened to it good before he bought it, and we also dredged the oil bag (swing arm) with a magnet and it came up clean.
badweatherbikers... Cool, a salesman at Riverside Harley told me about that site before I started coming to this one, but I never checked it out. He was trying to sell me a Buell at the time, and that's just not my style (whatever style an old fart like myself has).
Old 20th March 2015
wedge's Avatar
We have to figure this bike out. David is one of us now, we can't boot him out of the club (not alive anyway). We either have to learn about Buells or take him for a "ride".
Old 20th March 2015
nleco's Avatar
I mean... this IS a buell forum.
Old 20th March 2015
sportsterdoc's Avatar
Well, yes, but how many Forum members know enough about Buells to help?
General answer is that it is too lean off idle...the question is how to solve it...other than replacing the EFI with a carb ;-)
