0 One More Ohio Meet & Eat?
Last Post: toe
5 Favourite grips?
0 It's Glamazon's Birthday!
2 My 1275 Hammer Conversion..
0 Big bore Stroker problem
0 Oil leak
0 Done for now (no really)
Last Post: Pagey
0 Any Teamsters?
0 Bike wobble question
Last Post: semjpm
0 Any wealthy forum members?
0 2007 883R Roadster seat / tank & 2014 + slip ons
Last Post: jac737
0 Black drivetrain models?
0 stumble
Last Post: randy3934
0 Gear Spacing Question
0 New oil tank
0 Fyi
Last Post: salmanmr
fp3, fuelpak, idle, rev, stumble
Old 13th June 2015
lopezbc lopezbc is offline
Sportster/Buell Year: 2015
lopezbc is an unknown quantity at this point
Default Stumble when revving cold motor AFTER installing FuelPak FP3
Hey guys, looking for insight.
I have a 2015 Sportster 72 that I bought new. Dealer installed Shortshots for me prior to delivery and said there was no need to remap as I was only installing pipes, not intake as well. I dealt with the popping and such up until last week.
Flash forward about 3500 miles and I decided to add a Arlen Ness Stage 2 Big Sucker (the size more closely resembled the stock intake, which I liked) and a Vance & Hines FP3. I installed the map it recommended from my combo and then spent a weekend in AutoTune mode and then finished the Autotune setup. Bike runs fantastic, but only one "issue" that I'm hoping someone can clarify for me.
Upon starting the motor cold, for the first bit until it has been rode and armed up, if I try to blip the throttle quickly to rev it, it seems to choke and sputter, but never stalls. After riding for a bit, this seems to go away, so I'm not sure it's an issue. I'm just looking to see if anyone can verify IF it's a problem that I can fix, or can Vance & Hines support look at my map and correct something over the air for me to apply. Thanks for any input!
Old 13th June 2015
ivanford ivanford is offline
ivanford is just really niceivanford is just really niceivanford is just really niceivanford is just really niceivanford is just really niceivanford is just really niceivanford is just really niceivanford is just really niceivanford is just really niceivanford is just really niceivanford is just really nice
Sounds like it's over fuelling a bit, what is your miles per gallon figure like?
Old 13th June 2015
I guess I haven't paid much attention to it just yet in these few days. Is there something I can view in the FuelPak settings regarding that?
And I stand corrected. If I try to actually persist with a single rev long enough, it appears as though it will choke the motor to almost stall.
Last edited by lopezbc; 13th June 2015 at 20:23.. Reason: Add description of stall
Old 13th June 2015
twistingandturning's Avatar
twistingandturning twistingandturning is offline
Sportster/Buell Model: XL883N
Sportster/Buell Year: 2014
twistingandturning is an unknown quantity at this point
I've gotten the same stumble/choke on my 14 iron with a power vision. I'm not sure what it is, but I've gotten rid of it by trying out different tunes. Only happened before on cold starts until my idle would drop to normal.
