0 my local dealership closed today
Last Post: 8ball
0 Fork oil q
Last Post: Doc308
0 Fng
Last Post: XL1275
0 Knocking in Front Cylinder Until Warm (Before & After Rebuild)
Last Post: Jonzilla
0 73 Electric Start won’t run after firing
Last Post: Erikdowney18
0 New oil tank
0 Bean in a can (rattling when accelerating)
Last Post: rickxx
0 Regulator/rectifier question
Last Post: LenC
5 Is factory Stage 1 worthy?
0 Removing transmission 1973 XLH
0 Any Teamsters?
0 Royal Enfield speeding ahead in Asia
Last Post: Marsikus
0 07 Ign Acc position.
0 New member
0 newbie
0 Real Dogleg Levers - 1977 XLCR
Last Post: spiritof67
0 Hi everyone
Last Post: catpepper
0 2002 1200 XLC screamin Eagle air filter
Last Post: lespaul6
5 Blue V By Name?
Last Post: Clevspeed
Johnc (74), x750rider (67), bart53 (67), bad rad (66), halfdrive (55), jag1 (48), Zuhaib (36)
  #31
Old 27th August 2019
Skuzeee's Avatar
Skuzeee Skuzeee is offline
Sportster/Buell Model: Xl1200c
Skuzeee has disabled reputation
Can you flip that over and take a pick?
With those two bolts being loose, I'd be concerned about the condition of the rocker arm pads.
If those two bolts won't tighten up on your old heads, that definitely would explain the leaks.
Check the threads and check the bolts for warpage.
I can't remember if you checked the lower box for warpage but check that also with a straight edge if you haven't already.
That's not my pic, I needed the bike to get to work today, I'll hopefully work on it next week.
Sent from my SM-G973U using Tapatalk
Old 3rd September 2019
Skuzeee's Avatar
I'm working on the bike today, here are a couple flix, everything looked okay when I dismantled it:
XLFREAK XLFREAK is offline
No Posts
XLFREAK is an unknown quantity at this point
Unless it is the photos that rocker box looks like it has been welded, a lot, that would explain your leaks, replacement may be wise.
Old 4th September 2019
Skuzeee's Avatar
Those aren't welds, it's the chrome peeling
Hippysmack's Avatar
Yeah mine look the same. It's the chrome plating withering away.
Unless it's the pics, from the looks of the rocker arm pads, there is some wear there but it doesn't look like they are beyond use, from here anyway.
Have you checked the tops and bottoms for warpage with a straight edge yet?
Across the valve pockets looks to be a leaky area from here.
Big cams?
Here's the Sportsterpedia page on rocker box / rocker arm inspection
I see the lower box threads from the pics but I can't tell what shape they are in down in there.
How's the threads?
No Posts
Okay, understand what I am seeing now.
