0 manifold leaks
0 Where you carry your tool bag?
Last Post: Ted Town
0 XL FORUM Offcial Sciatica Thread
0 Bike sold leaving forum
0 It's sportsterdude.248's birthday!
Last Post: ReddTigger
0 Rico Lutsey aka Rico 05R
Last Post: SLW210
0 1960 XLCH in the UK
0 When Were You Born?
Last Post: old dog
0 Hi from Calgary
0 Hello from New York
0 Wet Sump Ifo, fix and tools
Last Post: old dog
0 Hi from North Wales, UK
Last Post: old dog
0 Collapsed lifter??
Last Post: vagrant318
0 V&H StraightShots Wrapped?
0 Hello
0 XLCH Crazy voltage spike
0 New to 2002 hugger 883
0 Dying battery, starter, mystery gremlin?
Last Post: 83XLX
0 My new LED headlight
0 Lets See your bike on a scenic overlook
Last Post: andy_t
0 83 xlx
Last Post: Island Dude
0 Your Favorite Style
Last Post: Lone Rider
0 Fuel injection quick connect o-ring
black pearl (75), SDREDD (58), pig (56), BonRu (54), cbass (46), ssm7530 (44), HawkeyeTX, SxysCowboy (36)
Old 14th July 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
Default WTF is it with these F'n rocker cover leaks!
I am getting really tired of rocker cover leaks every 500 miles. Ive been using the James gaskets and rubber on these. Ive got a set of the brown HD ones with the single ridge instead of double. Are they any better? I'm about to drill and tap for helicoils and crank these f'n covers down to 20ft.lbs. instead of 12.
Old 14th July 2019
Toejam503's Avatar
Air-Cooled Forever
Sportster/Buell Year #2: 1981
You may want to use the inch pound torque settings as they are probably more accurate than the really low ft/lb settings. The HD ones sound like a good idea. Good Luck!
Old 14th July 2019
juzyHD's Avatar
juzyHD juzyHD is offline
Bike Builder
Sportster/Buell Year: 1986
Weren't there some problems with bent covers on some bikes? Some specific years i think?
Old 14th July 2019
Hippysmack's Avatar
Any thoughts on spraying your gaskets with deodorant to see if it might be more than just rocker boxes?
Maybe CC pressure too high?
I'd buy having one set of bad gaskets but not more.
If it's only one side, it may be a gasket.
But both sides or more than just the box gaskets could be excess CC pressure.
Old 14th July 2019
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
Captain obvious says it’s probably not the gaskets
Old 14th July 2019
60Gunner's Avatar
Chief of Security
Well how would I lower cc pressure? I've got breather bolts with bigger holes than stock.
New umbrella valves?
Old 14th July 2019
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
Better ring seal or the newer oil pump with the larger scavenge section.
Old 14th July 2019
60Gunner's Avatar
Chief of Security
I'm pretty sure my new rings seated just fine. What about the cam cover mod I've reading. Drilling a hole and adding a fitting to put a hose with a pcv valve?
Maybe my umbrella valves are just shot. I don't puke any oil.
Old 14th July 2019
Dazed & Confused
Don't you only have 165 psi cranking pressure? A leak down test might be appropriate.
Old 14th July 2019
madnss's Avatar
I run 255 cc pressure and 210 cc pressure with zero issues and bone stock crank case venting . I’d look into something warped....
