0 manifold leaks
Last Post: hbsporty
0 Bike sold leaving forum
Last Post: A Seabee
0 DK Custom Bullet Visor Style Halogen Headlight Relocation Kits
0 It’s Glamazon’s Birthday!
Last Post: BSA Bob
0 Hammer / Axtell cylinder weights?
Last Post: rubine
10 how low do you let it idle
Last Post: csmith72
0 Headlight Temps with 55/60W bulb?
0 Brand new Golan petcock issue
0 Digital speedometer
Last Post: csmith72
0 1960 XLCH in the UK
0 DK Custom Billet Tank Lifts - New Sizes & Finish - Q&A
0 crank case breather
0 Shocks on CL for Ironhead?
Last Post: Whitewalls
0 stress killer
0 570's or 536, 560's @10:1 Compression
Last Post: Turbo Sporty 48
Last Post: Joe_jeep
0 *DK Custom - M8 Softail Passenger Pegs - Now You Have Options - Intro Savings*
branch, heads, o'keefe, porting, se536
Old 17th August 2019
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
It's all part of their BFH head service.
04/07 1275 BFH heads .590 cams S&S 1.725 rockers S&S premium lifters BDL+15% clutch TC88A HSR-45 S&S 3" ac LSR 2-1
NGOT8R NGOT8R is offline
Sportster/Buell Year: 2019
NGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to behold
My brother just had Branch O’keefe port the heads for his 2017 CVO SG and both intake/exhaust ports, as well as the combustion chamber are polished to a mirror finish. I always thought the intake port should have a rougher finish, but Branch swears by the mirror polishing to all areas on their heads as a performance enhancement.
Maxeffort's Avatar
Maxeffort Maxeffort is online now
Momentary Specialist
Sportster/Buell Model: XL1200
Ready to drop a valve into this cylinder too!
Sleepy Labeef rides again!
Old 18th August 2019
Maxeffort's Avatar
I finish ports with a 60 grit cartridge roll. Chamber with a cross buff.
Some of the cylinder head guys I know have gone to a carbide burr finish, even to the point of smoothing and shaping, then knock the whole port with a burr to put texture back into it.
The Branch Head has a beautiful polish to it. I guess it works for them. It also makes the customer feel good about the work.
One thing for sure, this highly polished head was loaded with carbon. It sticks to the polished surface very well!
I knew the head was ported, but not to what extent. I didn’t even realize the chamber was not “as cast” because the carbon was so thick. I had in the jet washer most of the day while cleaning other parts and I still had to do some hand cleaning.
Old 27th August 2019
tussuck tussuck is offline
Sportster/Buell Model: 883L
tussuck is an unknown quantity at this point
Where the valve stem enters the head ... they seemed to have removed a lot of metal that acts as a support for the guide. I have a set of Evo heads at home where the entire valve guide let loose due to not enough metal to hold it in place.
rocketmangb's Avatar
Well Jerry Branch is no longer with us
Before I had my first heads done I called Branch-OKeefe and was not impressed.
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
wedge's Avatar
wedge wedge is offline
That seems to be a product of CNC porting. It's actually my pet peeve. I prefer to do hand porting so I can retain the boats around the valve guides. Once those are machined out, there is turbulence created where the flow goes around that round guide. Kind of like a stream as it flows around a round boulder. Great for fishing, not so great for porting. Maybe the plan is to feed fuel to the gremlins that hide behind the guides?
wedge's Avatar
By the way, the theory behind a rough intake port surface is that a layer of air is trapped in the rough surface, and that layer of a/f mixture becomes the smooth surface that the rest of the flow travels over. So there is basically no difference between rough and smooth as far as the flow is concerned, so people don't waste the time to polish intakes. That is my understanding that dates back to studying Smokey Unic's early discoveries.
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
Pops Yoshimuras' theory. "If the ports are too large, make them rough. If the ports are too small, polish them."
Maxeffort's Avatar
Branch has made a "fin"(or wing) before and after the guide to split the flow around the guide. There is also a bias to the fin, to direct the air more to one side.
