0 back to factory clutch
Last Post: Bored now
0 15 min rides
Last Post: CMCSSeabee
Last Post: corndog76
0 Branch Mikuni Air cleaner question
0 Resto-Repair 84 ironhead
Last Post: lynnx
0 1960 XLCH in the UK
Last Post: lynnx
Last Post: Guidorey
0 E85 Fuel
Last Post: hondo
Last Post: fafcpa
0 Replacement Clutch/Rotor Magnets
0 97 Sportster Kickstand Problem
Last Post: Dirt Road Cowboy
0 removing clear coat on fork lowers
0 HELP! Extra part found
Last Post: syrnetworkin
0 48 O2 sensor?
Last Post: jvandivere
0 Starting issues (No Spark)
Last Post: jimstogs
0 The forum got talent
0 Battery melt down
0 Common ironhead problems
0 Hello from Tampa, Fl
0 Getting Hammered
Last Post: Bryan1976
0 Greetings from Denmark
Old 30th August 2019
Samson4651$ Samson4651$ is offline
Samson4651$ is an unknown quantity at this point
Default Engine knock
2001 Sportster Hammer 1250 kit with impact head service and Andrews N4 cams, Dyntek ignition. started with 1250 kit added cams and impact head work a couple years latter. had an issue with the wrong cam cover gasket which fit but wrong year started the bike tried to run a little thinking new start up oil needed to circulate. stop bike Hammer called the next day said they sent wrong gasket. I replaced and since engine knocking, don't believe its rod knock no up-down a little side to side. any suggestions Thanks, any way to upload a video/sound clip?
Have you been in touch with Hammer? They are excellent technicians and are very helpful...
Folkie's Avatar
Folkie Folkie is online now
Brass Nut
Sportster/Buell Year: 2015
Hi Samson4651$, welcome to the Forum.
You started your thread in the 'Forum FAQ / How To' section, which is for posts about the Forum, and how to use the forum functions, so I've moved it to the 'Sportster General Discussion and Problems ' section.
Folkie
South East England Riders
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
...I replaced and since engine knocking, don't believe its rod knock no up-down a little side to side. any suggestions?...
Your lifters are suspect if the "wrong" gasket kept them from getting oil.
Toejam503's Avatar
Air-Cooled Forever
Sportster/Buell Year #2: 1981
Did you relube the cams, etc. with a lubriplate or something when you replaced the gasket?
seajay's Avatar
seajay seajay is online now
Sportster/Buell Year: 04
Did you relieve pressure on the cams when you removed the cam cover?
rejeanprimeau's Avatar
How loud the knock, if very loud, check cams placement, if only a tick, your rocker shafts. They are simple engine.
Old 31st August 2019
Sportster/Buell Year: 1991
If you have the wrong cover gasket, one of the oil galleries could have been blocked, starving whatever it feeds of oil. Not good.
John
Old 3rd September 2019
ezmerf's Avatar
ezmerf ezmerf is offline
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1980
ezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant futureezmerf has a brilliant future
A mechanics stethoscope are cheap and will help you pin where the knock is coming from.
Murphy's Law :vvet:
