Last Post: Bored now
0 15 min rides
Last Post: CMCSSeabee
Last Post: corndog76
0 back to factory clutch
Last Post: Mark Jags
0 Branch Mikuni Air cleaner question
0 Resto-Repair 84 ironhead
Last Post: lynnx
0 1960 XLCH in the UK
Last Post: lynnx
Last Post: Guidorey
0 E85 Fuel
Last Post: hondo
Last Post: fafcpa
Last Post: fafcpa
0 Replacement Clutch/Rotor Magnets
0 97 Sportster Kickstand Problem
Last Post: Dirt Road Cowboy
0 removing clear coat on fork lowers
0 HELP! Extra part found
Last Post: syrnetworkin
0 48 O2 sensor?
Last Post: jvandivere
0 Starting issues (No Spark)
Last Post: jimstogs
0 The forum got talent
0 Battery melt down
0 Common ironhead problems
0 Hello from Tampa, Fl
0 Getting Hammered
Last Post: Bryan1976
0 Greetings from Denmark
Old 12th September 2019
Davo_137's Avatar
Davo_137 Davo_137 is offline
Default Plastic welders?
I’m thinking one of you skilled and knowledgeable gentlemen might be able to help me here.
I have a 5000 gallon polyethylene water tank that has about a 4-5 inch split at the bottom of the wall. I asked a water tank fabrication place to quote me for a repair, they came back with $300-400 without even looking at it. Now I have seen small plastic welding kits on the internet starting from around $50.
Considering when the tank is full it’s going to have about 20 ton of water inside of it. Do you think you could repair this split successfully using one of these plastic welding kits? And if so which kit would you use?
xena's Avatar
xena xena is offline
Assistant Administrator
I have not done plastic welding but researched a little to fix a split on an upper
portion of my kayak. There’s tons of first hand info and videos on YouTube.
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams, E1 clutch, Python 3 Slip ons
TC88A running Xena's (brand new) White Tiger Map
My 1212 Conversion Thread
Davo_137's Avatar
Ok
Thanks
Old 13th September 2019
gravydog's Avatar
gravydog gravydog is offline
Sportster/Buell Model: 1200 R
gravydog has a reputation beyond reputegravydog has a reputation beyond reputegravydog has a reputation beyond reputegravydog has a reputation beyond reputegravydog has a reputation beyond reputegravydog has a reputation beyond reputegravydog has a reputation beyond reputegravydog has a reputation beyond reputegravydog has a reputation beyond reputegravydog has a reputation beyond reputegravydog has a reputation beyond repute
I do auto collision repair for a living, we use plastic welders for repairing anything from bumper covers to windshield washer bottles.
At the lower end they are just basically glorified soldering irons, at the high end they use compressed air and nitrogen, and cost about $3000.
Talk to some local body shops, find one with the nitrogen welder, they should be able to help you. As for the pressure from 5000 pounds of water, there's only one way to know for sure.
If my aunt had balls she'd be my uncle.
Davo_137's Avatar
Ok, so the $300-400 quote might be justified, thanks dog
Crusty Crusty is online now
Sportster/Buell Year #2: 1978
Other Motorcycle Model: XLCH
Other Motorcycle Year: 1979
I don't think I saw a single house in inland Queensland that didn't have a good sized water tank, so I would think that if it could be done a lot cheaper, there would be no shortage of repair shops who would.
Then again, I saw a mechanic charge $180.00 (AU) to repair the threads on a control arm that was caused by his not tightening the nut and putting a cotter pin in to begin with.
When you consider how much it would cost to replace the water tank, the price to repair it isn't that bad.
Davo_137's Avatar
Haha yeah I have four water tanks, three 5000gal and a 10000gal. Strangely enough it’s hard to find someone to fix them and the people that make them are too busy making them I guess.
I did discover today one of the sections where i work has hand held poly pipe welders and the boss with access to them said I might be able to borrow one.He just needs to check that out with his boss. Then all I’ll need is a crash course on how to use it. It can’t be that hard to use them..it doesn’t need to be pretty.
DEEP DIVER's Avatar
Sportster/Buell Year: 1984
Sportster/Buell Year #2: 1993
Other Motorcycle Year: 1984
I've used them type of hot air guns to weld tarpaulins on curtain side trailers. There not for the sort of welding you want to do. Can you get inside the tank? if so drain it and patch from the inside as it will be stronger.
Davo_137's Avatar
There’s a hole in the roof big enough for a skinny person to fit into, unfortunately my mid section has grown since I quit smoking 3 years ago .
Apparently this is similar to what they have at work.
Old 14th September 2019
Water tight and strong enough to not burst when full are two different things. I would weld it if I could build some sort of container or reinforcement to support the repair. Otherwise I’d pay for the fix assuming it was warrantied to work.
Joe
