0 Talk to me about Painting
Last Post: brixtonanima
0 Mikuni 42 on 883
Last Post: Bow only
0 Harley Vincent?
0 Marrying used speedometer
0 Who runs 70wt. oil
0 USA made Stainless hardware better than stock
0 DK Custom Products License Plate Relocations
0 Resto-Repair 84 ironhead
Last Post: rocketnorton
0 Help me identify this bike
Last Post: AKL1
Last Post: thecarnie
0 Fi to carb
0 Diagnostic code ?
0 Front head gasket leak
Last Post: Scuba10jdl
0 Passenger peg relocation with Rinehart Fast Tracks exhaust
Last Post: GorilladaHun
0 muffler balance pipe
0 Do people notice your bike?
0 Lifters+w cams
Last Post: Gazotenekes
Last Post: 83ironman
0 FNG from Oregon
garyschmidt (78), JicJac (70), alleybabe (62), Galewarning (56), wngdweeler (51), scooter (47), kariglam1 (45), HERDYAN (45), V-XL (43)
help please, ironhead, problems, timing
Old 16th September 2014
Pan55's Avatar
Pan55 Pan55 is offline
Sportster/Buell Year: 77
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 77
Other Motorcycle Model: 1978 FX Shovelhead
Pan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to behold
#1 you didn't hone the cyl when installing new rings...not good...nothing for the rings to seat into..
#2 you didn't check ring endgaps...bad...could be that the cyls were already worn enough that you have excessive ring end gaps..
#3 you HAVE to readjust the pushrods to specs or actually for this purpose even a little looser....
#4 have you even had the bike started and run in to allow the rings to TRY to seat ?? can take quite a few miles..
#5 you mention re seating the valves ??? you would recheck** the compression everytime you re seated the vlaves...this has me scrathing my head...what exactly are you doing to "reseat"?? removing the head, and re lapping the valves?
IM not trying to bust your bubble here...BUT..you have basically done everything wrong possible as far as rebuilding a top end...
rideforfreedom rideforfreedom is offline
Sportster/Buell Model: xl883
rideforfreedom is an unknown quantity at this point
Yes I should've done all that sure, but I'm not looking for a super nice, reliable bike. That's what my BMW GS is for. It was never my full intention to rebuild the top end, I just figured I'd replace the things that were easy to get and work on. I re lapped the valves yes. I'm only in the US for less then two weeks so I'm really not looking for the perfect "do it right fix". I'll do that when I come back from England and have the actual time to do it right and to spec and all correctly. I'm just trying to get the bike running well enough to putt around on for the last few days I can. Ironmick, I'd love to get it up to operating temp if it ran well enough. My biggest problem is that the timing seems to be off, but why would it be? I really do not want to start screwing with things if I dont have to. So I guess my real question would be, how could the cam gears be off? and would it be gears if the push rod adjustment helped A LOT? I don't want to sound ungrateful or anything for having such an interesting and neat motorcycle, but it's not my daily driver bike or anything so I don't really feel the need to be perfect because I also just honestly don't have the time to be.
sportsterdood sportsterdood is offline
Sportster/Buell Year: 1982
sportsterdood is on a distinguished roadsportsterdood is on a distinguished road
The problem is unless it is done right you risk damage that is going to be quite costly down the road. Improperly installed rings will trash pistons, cylinders, and worse if metal gets into your bottom end. I'm no expert like a lot of these guys but seems to me you will be money ahead to wait until you can do it right, unless of course money is no object.
I'm getting 135 in the front and 125 in the rear after adjusting the push rods some more. It seems to be more of an adjustment problem rather than anything else. If anyone has some better insight on this I'd love to hear it! Like I've been saying before, the exhaust seems to be sucking in a tad bit so if some one would like to help assure me that it's my adjustment of the push rods that'd be pretty nice. I do appreciate the concern of me doing it "perfect", but it's not helping my current problem. I'd just like to have my fun bike running so I can hear the beautiful Harley sound.
So here's the latest. I put it all back together. She starts right up but pisses some gas at me from the carb and I had a puff of exhaust come at me as well. She runs well just is puffing back at me through the carb. Is this still push rod adjustments? Or is the timing off? Some info asap would be great!
Fridge's Avatar
Fridge Fridge is offline
Sportster/Buell Model: XLCH/H
Sportster/Buell Year: 1973
Other Motorcycle Model: Road King Classic FLHRCI
Other Motorcycle Year: 2007
Fridge has disabled reputation
I think it is still push rod adjustments.
Go thru the procedure again,exactly like in the video and make absolutely, positively sure that you have the one you are adjusting at it's lowest point,with the opposing one at it's highest.(front exhaust highest, rear exhaust lowest, = adjust rear exhaust)
Some guys put clothespins on the rods to better see the up/down motion and hone in on the lowest point. Put the adjustment at just a tick loose,rather than tight. After tightening the lock nut on the adjuster,check it again for tightness. Roll the motor around and check it again.Move on to the next one.
If it's not pushrods then I'd think it was valves not seating, for whatever reason or cams not right,but it seems every time you are adjusting the push rods, the motor is giving a better response.
Good luck and hope this helps.
dmac122's Avatar
dmac122 dmac122 is offline
Other Motorcycle Model: 2001 Electra Glide
dmac122 is on a distinguished roaddmac122 is on a distinguished road
Do the push rods adjustment again TOMORROW when the engine is stone cold even a little warm will throw off your adjustment. If you didn't open up the cam chest, your valve timing should be fine. You may have an ignition timing issue. How do you hear it sucking through the exhaust? Do you have exhaust or intake leaks?
Old 17th September 2014
Newest update: after fiddling with the pushrods once again, I think I have fixed the problem! I could hear/feel sucking in exhaust with the pipe off and just doing a test. Now after running it down the road (sort of) and letting it warm up I'm going to wait till it cools down and check my adjustments. Then I'll repeat the putting down the road and back and do a compression test again. Thank you so much to everyone who has helped on this forum! I really do appreciate it all! Hopefully someone else in my situation can learn from this thread and hopefully it helps them as well!
Old 18th September 2014
Mosey Mosey is offline
Other Motorcycle Model: FX
Other Motorcycle Year: 1976
Do not touch that bike until tomorrow if yer gonna adjust the pushrods. It must be stone-friggin' cold.
Have you watched the video in the Stickies? If not, watch and do it exactly as shown and you'll be golden. The pushrods need to spin freely with zero up-and-down play AFTER tightening the locknuts.
You've gotten a lot of top-shelf advice from very knowledgeable folks in this thread. Re-read and pay close attention to all the previous posts.
Do you have a Factory Service Manual for your year bike? Best tool you can have. Period. Exclamation point!
