0 Talk to me about Painting
Last Post: brixtonanima
0 Marrying used speedometer
0 Mikuni 42 on 883
0 Who runs 70wt. oil
0 USA made Stainless hardware better than stock
0 DK Custom Products License Plate Relocations
0 Harley Vincent?
Last Post: Ted Town
0 Resto-Repair 84 ironhead
Last Post: rocketnorton
0 Help me identify this bike
Last Post: AKL1
Last Post: thecarnie
0 Fi to carb
0 Diagnostic code ?
0 Front head gasket leak
Last Post: Scuba10jdl
0 Passenger peg relocation with Rinehart Fast Tracks exhaust
Last Post: GorilladaHun
0 muffler balance pipe
0 Do people notice your bike?
0 Lifters+w cams
Last Post: Gazotenekes
Last Post: 83ironman
0 FNG from Oregon
0 Hello from Centurion, Gauteng, South Africa
garyschmidt (78), JicJac (70), alleybabe (62), Galewarning (56), wngdweeler (51), scooter (47), kariglam1 (45), HERDYAN (45), V-XL (43)
carb, harley, ironhead, keihin, sportster
Old 28th February 2015
Boxerguy8888 Boxerguy8888 is offline
Sportster/Buell Year: 1973
Boxerguy8888 is an unknown quantity at this point
Those jets are typical for that carb. I would clean the carb and run it as is for a while, then see if it may benefit from re-jetting ...
Cleaning a Carb
http://xlforum.net/forums/s...d.php?t=185361
Note: a piece of angle-aluminum works better for the carb stand than does the flat steel pictured in the Sticky.
Sounds like a plan. I'm going through everything now and cleaning and collecting what parts I still need. Right now I'm working with the carb and rebuilding the front master cylinder, it was in rough shape. Right now I have the carb soaking and the brakes are doing the same so I can hopefully get the piston to come out tomorrow.
Racepres's Avatar
Racepres Racepres is offline
Racepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to behold
LMK what Air cleaner you will be running, K&N, or Paper, or Sponge...It makes a difference on Jetting...Alot.
Old 1st March 2015
Havnt decided yet, gonna be awhile before I get there. I have k&n in my truck and like being able to re-use but I've heard the foam are good for breathability. I like the look of velocity stacks but would never use one. Rather not be sucking a bunch of grit into the engine.
Old 1st March 2015
Racepres's Avatar
I can prove that a Filthy K&N will outflow a Spinnin new Sponge...
Drop me a Note when you get an air cleaner...then I'll give you the jet sizes we are using with a Similar setup...
Old 1st March 2015
I'll be sure to do that, thank you. I'm sure I'll have plenty more issues to deal with before then also! My manual has alot but not everything.
