0 Resto-Repair 84 ironhead
Last Post: Robyart
0 fp3
Last Post: 11alan111
Last Post: Bow only
Last Post: SLW210
0 Digital odometer
Last Post: shrimp
0 No spark
0 xied or x14ied?
0 My 900: half-H, half-CH
Last Post: 83ironman
0 Shaking front end
Last Post: koolbreeze
0 Speedometer hookup - 76 XLH
Last Post: Mission1
Last Post: 201648Rider
Last Post: jazzman
0 Smaller turn signals
Last Post: lehel
0 86-90 regulator-rectifier on 2003 engine?
Last Post: lehel
0 Intake seals, glad I checked them
0 Spark Plugs
mcevoy, Dnight (54), alvin01101 (54), rahean (52), 2005883c (46), cliff883 (45), HotRodSporty (44), Wes Marshall (41), liquidice148 (34)
2000, contrast, custom, rims, wheels
Old 7th February 2016
groovemeisterus's Avatar
groovemeisterus groovemeisterus is offline
Sportster/Buell Model: XL883-1200 Branch Build
groovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of lightgroovemeisterus is a glorious beacon of light
Question Custom Stock Size Rims
I'm pretty much done with inside the engine. Now to spend time on the looks of my bike. I've looked some, but do not usually see a good selection (from my likes) of custom stock size black contrast rims. Usually only find big twin sizes.
Any links, picts of your rims with size etc would be appreciated. My bike has stock 2000 883 XL cast rims. Not sure if want to send them off and get powder coated black (pros and cons?), and have the 9 cast spokes edge be shaved or what not to achieve the contrast effect.
Or to find a nice set of brand new black and aluminum/chrome contrast rims that look good.
Or if can only use similar size rims, what mods need to be done, bearings, axle, spacers etc.
Just starting to learn on this end. Moving on from engine, until maybe new 6 speed gears, or custom set of gears installed, with one tooth lower engine sprocket, and 5th gear to match lower RPM's on highway riding.
Thanks for any input.
883 XL Y2K - BLACK,Ported Manifold,HSR 42mm Carb,Branch #5 Ported 883 Heads,Bob Woods W8S 0.590" Cams, SE -0.050" Perfect Fit Pushrods,SE 1200 Ignition Module ,Vance & Hines Straight Shot Exhaust,07 SE Air Cleaner,SE 40,000V Red Perf Coil,883 Jugs Precision Bored for Branch 30º Domed Pistons,& One Big Smile ;o), ~83TQ, ~83HP for now.
