0 FNG from Oregon
0 Diagnostic code ?
0 Marrying used speedometer
0 Sup yall
0 XL Forum will now be the Suzuki Intruder Forum
Last Post: bill smith
0 68 XLCH - Insight Plz
Last Post: Bow only
0 Hello from Centurion, Gauteng, South Africa
0 Help me identify this bike
Last Post: AKL1
0 Never seen this before...
Last Post: smac74
0 Mikuni 42 on 883
Last Post: ronccc
0 WTB saddlebags
Last Post: Jcolleyoh
Last Post: mastiffhound
Last Post: Kbetts
0 15 min rides
0 Do people notice your bike?
0 Carby cough
Last Post: connorneil13
0 HF bike lift
Last Post: Bryan83taco
0 Need help picking new mufflers
Last Post: Joe_jeep
0 cycle shack 1.75" slip ons without a tune?
Last Post: Joe_jeep
0 What if? race ITT 1250
garyschmidt (78), JicJac (70), alleybabe (62), Galewarning (56), wngdweeler (51), scooter (47), kariglam1 (45), HERDYAN (45), V-XL (43)
#ironhead
Old 1st November 2019
Donklandes Donklandes is offline
Sportster/Buell Year: 1981
Donklandes is an unknown quantity at this point
Default 81 ironhead 1000 bore .40 over Andrew's r5 cams
New to the forum! I got a 1981 Irοnhead 1000cc bore .40 over with Andrew's R5 cams. On the flywheel there is three timing marks (vertical line, single dot, and lazy 8?). I know the timing marks on the cams all have to be aligned. But does the motor have to be TDC for that? If so which timing mark do I use? And what's the easiest way to install the pushrods after installing the cams?
Old 2nd November 2019
Folkie's Avatar
Folkie Folkie is online now
Brass Nut
Sportster/Buell Year: 2015
Hi Donklandes, welcome to the Forum.
You started your thread in the 'Forum FAQ / How To' section, which is for posts about the Forum, and how to use the forum functions, so I've moved it to the 'Irοnhead' section.
Folkie
South East England Riders
Thanks Folkie appreciate it!
doodah man's Avatar
don't look at the flywheel marks for cam timing, just line up cam #2 to the pinion gear mark first and then make the others fall in line with the rest of the cam marks. once that is done and the cam cover is back on the easiest way to get the push rods back in is to put one cylinder or the other on the compression stroke (both intake and exhaust will be at the lowest point) then install and adjust the push both rods before moving on to the other pair. i always have to pry a bit to get the exhaust push rods seated, even with the adjusters bottomed out. if that happens to you just know that you will have to overcome the valve spring tension a little to get them seated. • i use an open end wrench small enough that the ball on the rod will sit on the "rails" then leverage it up into place • no such issue on mine with the intakes. good luck, have fun! welcome to the forum!!
to start rotate the motor until the mark on the pinion gear is at the 11:00 position before installing#2.
Old 3rd November 2019
Welcome to the forum family from a swamp in Michigan.
